Could I Use MDF To Reproduce Exterior Wood Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-19-2009, 07:18 PM   #1
Could I use MDF to reproduce exterior wood siding?
Rookie question maybe....
But the high content of non-biological additives (and low price) have pushed me to ask you guys:
Would it be a good/Bad idea to reproduce some damaged exterior wood siding in MDF? Ripped, Routered and coated in a good ext. paint.
I googled and all I could find was a comparison between different types of MDF. Not a "fiberboard Vs. real wood" comparo.
* Here's some of that info in case anyone is interested (or can tell the wood content of the MDF you are buying?)
Good Luck: http://www.woodweb.com/knowledge_bas...nsity_fib.html
Main Question - Can painted MDF stand up to exterior use?
Thanks for any info guys!
1forest1 is offline   Reply With Quote
Old 11-19-2009, 08:10 PM   #2
ArmchairDIY's Avatar
Bad idea.
MDF is not intended for high moisture areas. There is a water resistant MDF manufacture, the brand name eludes me at the moment. But I believe the indented purpose is occasional water contact such as a sink leak, not exterior applications.
What profile do you need to match?
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself! ArmchairDIY.com
ArmchairDIY is offline   Reply With Quote
Old 11-19-2009, 09:03 PM   #3
Remodeling Contractor
MDF cannot be used for exterior application. MDO can but would not be a good selection. Use Azek sheets. You can shape it to anything you like, paint to match other trim and it will not rot or attract insects.
Vinyl Siding Not Locking In Place Konfrst Building & Construction 13 11-17-2009 09:40 PM
New siding, paint exsisting siding, or powerwash?? fixiechick General DIY Discussions 5 01-22-2009 11:50 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
