Cottage Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 01:28 PM   #1
Smile
cottage insulation
We have a cottage that sits 3 feet off the ground, the previous owners put insulation underneath it, which is held up with vapor barrier and in some areas plywood sheets.
We are now putting in an 8 ft high basment. This insulation will now be in our ceiling of the basment. Since this is our cottage we do not heat it in the winter months when we don't use it. Water is turned off, and drained.
We were told we need to heat the basement over the winter so it does not freeze, we will keep it at 40F. We will be insulating the basement walls and floors, to help cut the heating cost in the winter months.
Our concern is the isulation in the ceiling. Will the vapor barrier create mildew/condensation?
Thanks for any information we receive.
Cottagers is offline   Reply With Quote
Old 05-02-2010, 01:48 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I would remove the vapor barrier, but keep the insulation. You could hold it by nailing small pieces of lumber across the joists or something.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
