Cost Of Pumped Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 07:49 PM   #1
Rewards Points: 93
Cost of Pumped Concrete
I am building a deck in my backyard and cannot get a truck back there. The truck would need to pump the concrete about 60ft. Any idea what it would cost for about 2.5 cubic yards fo concrete to be pumped in for the footers? Tryign to decide if its worth looking into or if I should suck it up and mix and pour the 13 footers (36" deep) myself.
jsbeckton is offline   Reply With Quote
Old 05-15-2011, 08:48 PM   #2
Rewards Points: 1,016
I think you will find pricing can vary area to area. Just call a few pumpers and ask. Your concrete supplier may provide pumping services as well, and if not they will have a list of pumpers they like to work with.
You may have a price diff for small and large stone in the concrete mix - smaller pumper needed for smaller stone. I did a patio with smaller stone to get the price of the pumper cheaper vs. larger stone for the slab on grade foundation for my 24x30 workshop.
Other options are to rent a concrete buggy or get a concrete trailer if you can get either of those in there.
Old 05-15-2011, 09:21 PM   #3
Rewards Points: 4,538
for that distance & cy, a trlr-mtd pump will be the least expensive,,, don't forget to ask your pumper how many cy to prime it,,, he &/or the plant will probably have mix recommendations.
Old 05-15-2011, 09:50 PM   #4
Rewards Points: 93
Any idea on the ballpark cost? I would probably be wiling to pay $200-$300. Any more than that and I would just do it myself. Is it worth calling if that is all I am willing to spend?
Old 05-16-2011, 06:02 AM   #5
none whatsoever as we primarily work in e cobb ( atlanta ),,, our trlr pumper's rate is $400 for 1/2day + cost of the redi-mix mud but all depends on what your time & back are worth,,, that's a lot of humping for 1 guy,,, naturally i don't pay it as it all gets passed on to the end user ( in this instance, you ! ) since you're a 1-time customer, don't think the price is negotiable,,, don't plan on any extracurricular activities till the pain wears off & the aleve bottle's emptied - you're a better man than i
Old 05-16-2011, 09:47 AM   #6
Civil Engineer
Rewards Points: 4,576
Your arithmetic seems a bit high. You say you are putting in 13 tubes at 36 inches each, that makes a total of 39 feet of concrete. If you use a 12 inch sonotube (pretty common for footers), that makes a total of about 30 cubic feet, or about 1.1 cubic yard, not the 2.5 yards you quoted. Unless you are using 18 inch tubes?
I put in nine 12 inch diameter concrete footers for my deck, they varied from 36 to 48 inches deep (a few hit ledge before they hit 48 inches). I had a similar problem, so I mixed the concrete by hand in a plastic tub and wheelbarrowed it over. I did have the gravel and sand delivered to my backyard, they were small trucks and could fit whereas a concrete truck would never have made it. It wasn't too bad of a job. I did it solo, but I would suggest getting a helper, buy them some beer. And do the work on a cool day, the concrete sets better, and you will feel a lot better about the work. But I don't know that I would care to mix up 2.5 yards, I only put in about 1.25 yards, and that was enough.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
jsbeckton (05-16-2011)
Old 05-16-2011, 09:05 PM   #7
Rewards Points: 93
Thanks Daniel. I was thinking I needed 18" but the inspector said I could do 12" and just try to flare out the bottom to 18. With that I expect it to be about 1.2 cuyds which seems much more managable. Probably not worth a pumper.
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
What is the cost of adding brick ledge to new construction? toddtx Building & Construction 4 01-13-2011 07:04 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
