Cost To Lift House And Put In New Foundation - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-30-2012, 05:34 PM   #31
Rewards Points: 960
congratulations.
cleveman is offline   Reply With Quote
Old 08-30-2012, 06:09 PM   #32
Rewards Points: 3,722
Originally Posted by ivanator View Post
I ended up replacing a section of the foundation that was crawl space. I/3 of the house had a crawl space, and the stone foundation only went 24 inches below grade, instead of the required 42 inches. There was no footing. It was also put on really organic soil, which ended up running about 3-4 feet below grade in some spots.
So I had this part of the house lifted to level. It had settled 8 inches over 16 feet. The foundation was excavated and a new block foundation was put in, full basement height with proper footings.
This has all come in at 1/10th the possible cost tossed about by the engineer who came out to take a look. No general contractor, no engineer.
Yup,all those engineer types do like to throw out big numbers,congratulations on the job,nicely done.
Canarywood1 is offline   Reply With Quote
Old 04-04-2013, 12:22 PM   #33
Here is your answer you want.
Don't listen to any of these idiots on this page. They have no clue what they are talking about.
To lift a house, it's all about the dimensions. Doesn't matter how heavy it is or anything. The second thing is the basement and where the lift equipment needs to lift from. Concrete basement, means that it prolly will crack with the weight of the house.
To life a basement it should only cost 10-15K Depends on the size, yours will be anywhere from 12-15K. That is lifting and excavating to make a new basement or doing any extra work with moving the dirt or debris under the house out, to build the new foundation. Not the issues
The issue if finding a good masonry contractor who can work with your foundation. When it is lifted, if they need to post new wood planks, that will cost you $2,000-$5,000. That is where your house will attach to the actual new foundation, concrete.
The actual process of putting up the wall is what gets tricky. With whatever drains you chose, concrete, rocks, concrete flood finishing the walls with drywall etc. It can run you up to 10-20K. Remember you might need to run new elec, plumbing and such. If some of it needs to be fixed, might as well push in the extra cash to get it all done and not have to worry about anything for a LONG ASS TIME. lol
But the return of all this, refinance the house, will be great. Say this house was worth 100K. Doing the new basement, plumbing, elec, foundation. Will bring this house 100% above the rate. You're refinance will get you @80% $80,000 in pocket. which pays off the bills that you had to do the work and 30K extra to pay back towards the house.
****, might as well take that extra cash and put in new windows, insulation, drywall, paint, bathroom, kitchen supplies. Guess what, that refinance goes up again another 20%. It's all a win win game when you fix up a home. It's up to you if you want to spend the time to do the work and be amazed at how will it will look after it's done :D
A lift and escalation should NEVER take over a week. the foundation itself, should never take more than 2 weeks. Setting flooring, tiles, block wall, new wood (if needed), inspection and set the house back down on it.
Good Luck. Hope that my response helped, since the idiots in here didn't really have anything knowledgeable to say.
dabeleg13 is offline   Reply With Quote
Old 04-04-2013, 12:37 PM   #34
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
I find it funny that a smart guy like you didn't notice that the OP already has the project done.
I guess that is something that only an idiot would notice though.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 04-04-2013, 02:31 PM   #35
GBrackins's Avatar
Rewards Points: 2,108
Andy,
you buying what he's selling????? LOL
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-04-2013, 02:55 PM   #36
Lord of Slums
Rewards Points: 1,974
This post revival is exactly on time for a project I am working on. Thanks for the help, people of the past.
mj12 is offline   Reply With Quote
Old 04-04-2013, 03:05 PM   #37
GBrackins's Avatar
Good Luck mj
Gary
