Cost Effective Home Plan - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2010, 05:12 PM   #1
Cost effective home plan
What is the most cost effective home plan for a 2500sqft home. Is a simple a frame house with dormers the best way to go.
I am in Charlotte NC
abbey1 is offline   Reply With Quote
Old 08-26-2010, 05:47 PM   #2
Rewards Points: 30
Is this a long term residence or one you plan on selling for profit?What size lot?Urban or rural?What is your budget?Hiring all work?
daveb1 is offline   Reply With Quote
Old 08-26-2010, 06:49 PM   #3
home plan
Long term, suburbs, 1 acre in a neighborhood that has 30 houses all on 1 acre lots. the lot is wooded, flat, hiring all work out, I may clean,lay tile, landscape, install fence.
Thanks,
Old 08-26-2010, 07:05 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
dormers add to the cost of the structure as well as add complexity and cost to the roof structure and as a result, the supporting building becomes more complex and expensive.
the most cost effective would be a very basic rectangle with a flat but low slope roof. For cost purposes, using rafters and a load bearing wall to split the width of the span would be cheaper than trusses.
minimal windows.
most people don't really want cost efficient. They like at least a little bit of fancy.
Old 08-26-2010, 07:32 PM   #5
Old School
Willie T's Avatar
Nap is right about actually wanting more than we think we do.
Simply look at what your are driving. Is it a Yugo?
Willie T
Old 08-26-2010, 07:43 PM   #6
jlhaslip's Avatar
Rewards Points: 1,528
minimal exterior corners, no roof adornments, plumbing on back-to-back walls and minimal hallways
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 08-26-2010, 08:40 PM   #7
Registered User
Rewards Points: 5,492
Floor plan to fit 2' or 4' increments, no waste. (Decking, sheathing-wall and roof, tile, backer board, drywall, trusses, etc.) Advanced framing: http://books.google.com/books?id=LR4...raming&f=false
http://books.google.com/books?id=9wk...raming&f=false
Gary
Old 08-27-2010, 01:41 AM   #8
A rectangle with an aspect ratio calculated to minimize costs.
For example, a 50'x50' square (2500 sq. ft.) would minimize wall materials (4 * 50' = 200 linear ft.) but have a huge roof span (even adding a bunch of lally poles to minimize the structure required, any roof with a reasonable pitch would get really tall in the middle and I assume flat roofs are relatively expensive).
The other extreme, a 10'x250' long skinny rectangle (also 2500 sq. ft.) could have a trivial shed roof but would maximize wall materials (2 * 10' + 2 * 250' = 510 linear ft.).
Pick an aspect ratio somewhere in the middle and calculate its costs, along with the two extremes I mentioned. Plot them on a graph (aspect ratio vs. cost), and you'll get a curve. Repeatedly interpolate with new aspect ratios until you find the minimum.
Obviously, you want no non-load-bearing walls, the minimum amount of doors and window area required by code, and exactly one sink (the bathroom and kitchen can share, right?). Use the concrete slab foundation as the finished floor.
I think you should look into steel buildings (the kind people use for warehouses and stuff).... those are designed to provide minimum cost per sq. ft.
Hope that helps!
JackG is offline   Reply With Quote
Old 08-27-2010, 12:11 PM   #9
Rewards Points: 1,910
If your property is suitable a simple rectangle shaped split foyer with 1250 ft up and 1250 ft down is usually very economical.
Costs estimate help please for a newbie Basement vs crawl space Cancer Researcher Building & Construction 21 03-30-2012 06:59 AM
most cost effective house plan ugabulldog Building & Construction 12 01-03-2010 01:10 PM
NEWBIE- Looking to build my own Barn Home in Idaho LAWFISH General DIY Discussions 2 11-14-2008 07:43 PM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 08:44 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
