Cost Of Contractor Install Crawl Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 10:10 PM   #1
Question
Cost of contractor install crawl insulation
I live in an 8 unit (4 up, 4 down) condo in southern Indiana. The building has 4 shallow crawl spaces, each about 1,000 sq ft. They are connected in pairs with 2 doors, 1 on each end. Without getting into much detail, they paid to have the fiberglass insulation between the joists removed to create a conditioned space.
They then discovered local regs required fire barrier protections and raised other issues. So they decided to return the spaces to vented "as-built" condition. A crew (about 4 workers) spent less than a day (6 hours?) re-installing fiberglass insulation between the joists. I estimate the 4,000 sq ft of R-19 CertainTeed Kraft-Faced Fiber Glass at the local Menards would have cost the contractor about $1,600.
My question: What would be a reasonable price for this job?
Frank Fitzgeral is offline   Reply With Quote
Old 07-12-2011, 06:47 AM   #2
DIY staff
Rewards Points: 7,174
The job is done and paid for--Look at the bill---your answer is there.
Reasonable is what a seller and buyer agree upon.
Old 07-12-2011, 07:09 AM   #3
Waaay overcharged?
Unfortunately, they are resisting disclosing the invoice (they are consulting a lawyer) and I am contending they were waaay overcharged. I'd simply like to get some professional estimates to sense if I am waaay out of line.
BTW, last night I couldn't sign in with this membership and ended up re-registering.
whatever419 is offline   Reply With Quote
The Following User Says Thank You to whatever419 For This Useful Post:
oh'mike (07-12-2011)
Old 07-12-2011, 07:06 PM   #4
DIY staff
Not knowing the site ---Usually $1.00 per square foot on the cheap end to $1.50 or so.
I haven't had a pro install insulation in some time--so these prices could be low.
If you have a library or Borders book shop near by Look at the estimating books by RS Means or the Craftsman series.----They have pricing by region----the books are updated yearly--the book store might have the up to date volume.
Old 07-12-2011, 10:26 PM   #5
Thanks. This is very helpful.
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
crawl space insulation thevoz Building & Construction 6 01-09-2010 11:56 PM
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 11:36 AM
Crawl Space Insulation howard.wheaton Remodeling 4 11-10-2008 07:12 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
