Cost Of Building And Labor In A 20 X 20 X 20 X 20 Two Story Home. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 09:23 PM   #1
cost of building and labor in a 20 x 20 x 20 x 20 two story home.
I am going to build a 20x20x20x20 two story cabin (stick house) and am going to add 4 x 12 hemlock logs and chinking later. need to figure cinder block foundation, subfloor, windows and doors so i can get it in the dry at least. how much would this cost to get all this put in the dry?
Buildme is offline   Reply With Quote
Old 09-08-2011, 09:31 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
How much do you want to spend?
What is your full name, address, date of birth, and social security number and we can get started right away.
Old 09-08-2011, 09:54 PM   #3
Rewards Points: 6,652
You are talking about a log home. With labor, plans, cost for the company you buy it from to produce, build, tear, then deliver & set up, structure alone for materials and finish could be $80,000, it could be $250,000. Cost to purchase the property, could be $9,000, could be $110,000. Can't really tell you, because this is the Internet, not a real person that you need to talk to, that deals with this stuff in your area on a full time basis.
Old 09-08-2011, 09:55 PM   #4
Framing Contractor
Good Luck getting an answer.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-09-2011, 01:10 AM   #5
Rewards Points: 1,092
"Good Luck getting an answer", especially since you've gone into the 4th dimension. That last one will take some thinking. All kidding aside, you can easily estimate that with a call to your local Ho De Po store, etc. Builders in our area charge anywhere from $120 to $180/sf, turn-key house. Call a few banks or contractors and see what their sf price is; the materials will be about 40-50% of that.
Old 09-12-2011, 10:35 AM   #6
Thank you for pointing that out. I am waiting with bated breath as to the technology involved in this dwelling. I assume it will be named "Tardis, Type 40."
rico567 is offline   Reply With Quote
Old 09-12-2011, 01:54 PM   #7
Framing Contractor
Rewards Points: 118
20x20x20x20? Does this house pass into another dimension? Not sure how I bid that. Usually sq ft or cubic ft, but with the fourth dimension I may need to consult with Einstein.
sixeightten is offline   Reply With Quote
Old 09-12-2011, 02:56 PM   #8
Rewards Points: 2,238
I just talked with Einstein -
told me E=MC2.
Hope that helps!
RF
rossfingal is offline   Reply With Quote
Old 09-12-2011, 03:11 PM   #9
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Check on your local codes about using the 4th dimension. Sometimes alternative universes fall under that alternative municipality's rules.
Red Squirrel is online now   Reply With Quote
The Following User Says Thank You to Red Squirrel For This Useful Post:
AndyGump (09-14-2011)
Old 09-12-2011, 03:28 PM   #10
Hey, don't dis the Dr.
The Following User Says Thank You to gregzoll For This Useful Post:
jbfan (09-14-2011)
Old 09-14-2011, 09:47 PM   #11
So I'm guessing that 20x20x20x20 means that the building is to be 20x20 two story, or one story/with basment. I built a 20x20 cabin with loft. windows, doors, roof, electrical and insulation ran me about $9000.00. this building I put right on the ground on wood blocks, so I saved some there. that is the best i can do.
Redsy is offline   Reply With Quote
Old 09-14-2011, 09:56 PM   #12
Framing Contractor
It's nice to have a comedian on the forum.
Joe Carola
Old 09-14-2011, 10:04 PM   #13
Learning by Doing
Leah Frances's Avatar
Heh heh TARDIS. good one, Rico.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 09-14-2011, 10:30 PM   #14
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Leah, I was in love with you until I found out you are a Dr. Who fan.
Well, no-one is perfect.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
gregzoll (09-15-2011)
Old 09-15-2011, 06:51 PM   #15
DIY staff
Rewards Points: 7,174
Tardif-Tardis----Andy did you design the original and the producers misspelled the name?
And you still resent it after all these years?
