Cosmetic Mortar Coating Over Chimney. How Thick? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-14-2009, 05:21 PM   #1
Cosmetic mortar coating over chimney. How thick?
Probably too late, but today I installed metal lathe over our chimney and set it in place with galvanized masonry screws and washers.
I'm using a type S masonry mix and have the mesh and screw heads covered with mortar. It's a about 1/4" in most places but perhaps a little thinner in others.
Since this is only for looks and will be painted next Spring, is this about right or should I go over it with another thin coat? Same mix or something different?
Thanks.
meltdowndave is offline   Reply With Quote
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
Chimney repair: rebuild or repoint? cloud9 Building & Construction 33 09-22-2009 09:12 PM
Painting exterior brick with latex? hellothere123 Painting 10 09-19-2008 08:50 AM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
