Correcting Slightly Uneven Small Concrete Surface - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 10:43 PM   #1
Rewards Points: 1,062
Question
correcting slightly uneven small concrete surface
so i have this protruding concrete figure in my multi-level basement which is more like a step but will not be used a step. will be more like a living room corner caved in shelf inlet or whatever you call it but that does not matter that much.
since the position was kind of odd, the framing i put together was slightly imperfect (i typically am a perfectionist when it comes to concrete frames) and this step slopes very, very little (perhaps < 1/8" over a foot or so) and i would like to fix it. there will be carpet over it so ...
is there some solution that i can apply a thin layer of to correct the unevenness ? something like thinset or something to that effect. or something like linoleum that i can glue to concrete before i have a carpet installed. i think an applied solution would work better because it could be measured as is being applied.
thanks,
- a -
Old 01-14-2008, 11:35 PM   #2
ICF Construction
Self leveling floor material available at most home centers
But for < 1/8", I personally would let it go, once carpet is down it should almost disappear. If someone came to my house a complained about that little amount I would show them the front door and hopefully it does not hit them on the way out!!!
Chris
Chris Johnson is offline   Reply With Quote
Old 01-15-2008, 09:14 AM   #3
Exclamation
thanks. my perfectionist self is one of my greatest enemies ...
Old 01-15-2008, 09:27 AM   #4
Question
Btw
can you think of a brand name for the self-leveling material you are talking about ? sound kind of generic ...
Old 01-15-2008, 09:43 PM   #5
ICF Construction
L&M, Mapei, Custom....etc, etc
There is lots available, each area/state has preference for what is carried/sold, you will just have to see what is available in your market.
Chris
Old 01-16-2008, 08:38 PM   #6
Rewards Points: 150
I would recommend leaving it alone, but if you cannot be stopped . .
Then use Cement All by Rapid Set. Mix, trowel, screed and it dries fast. It can be feather edged.
kgphoto is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
