-   -   correcting slightly uneven small concrete surface (http://www.diychatroom.com/f19/correcting-slightly-uneven-small-concrete-surface-15622/)
amakarevic 01-14-2008 10:43 PM
so i have this protruding concrete figure in my multi-level basement which is more like a step but will not be used a step. will be more like a living room corner caved in shelf inlet or whatever you call it but that does not matter that much.
since the position was kind of odd, the framing i put together was slightly imperfect (i typically am a perfectionist when it comes to concrete frames) and this step slopes very, very little (perhaps < 1/8" over a foot or so) and i would like to fix it. there will be carpet over it so ...
is there some solution that i can apply a thin layer of to correct the unevenness ? something like thinset or something to that effect. or something like linoleum that i can glue to concrete before i have a carpet installed. i think an applied solution would work better because it could be measured as is being applied.
thanks,
- a -
Chris Johnson 01-14-2008 11:35 PM
Self leveling floor material available at most home centers
But for < 1/8", I personally would let it go, once carpet is down it should almost disappear. If someone came to my house a complained about that little amount I would show them the front door and hopefully it does not hit them on the way out!!!
amakarevic 01-15-2008 09:14 AM
thanks. my perfectionist self is one of my greatest enemies ...
amakarevic 01-15-2008 09:27 AM
Btw
can you think of a brand name for the self-leveling material you are talking about ? sound kind of generic ...
Chris Johnson 01-15-2008 09:43 PM
L&M, Mapei, Custom....etc, etc
There is lots available, each area/state has preference for what is carried/sold, you will just have to see what is available in your market.
kgphoto 01-16-2008 08:38 PM
I would recommend leaving it alone, but if you cannot be stopped . . :)
Then use Cement All by Rapid Set. Mix, trowel, screed and it dries fast. It can be feather edged.
