Correct Wood For Exterior Handrail? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-19-2009, 04:55 PM   #1
Rewards Points: 682
Correct wood for exterior handrail?
I have a small balcony that needs the wood rail cap replaced (I guess that's what you call it). It is badly deteriorated.
I was thinking about just replacing it with douglas fir, primed and painted. I was experimenting awhile with different woods for exterior gates and fences, and I wasn't happy. For example, I built a gate out of redwood, but then learned if it was not heartwood (all deep red) then it wasn't much good.
Also I hear cedar is the same, if it's not all heartwood it's not much better than douglas fir.
Anyone have their opinion on this.
darsunt is offline   Reply With Quote
Old 11-19-2009, 05:04 PM   #2
Drywall contractor
Rewards Points: 1,070
Pressure treated or "composite" will withstand the elements best....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-19-2009, 05:17 PM   #3
Rewards Points: 682
Composite sounds interesting. I'll have to check it out.
Pressure treated, I'm concerned it will warp. Also don't want to wait 6 months before painting it.
Old 11-19-2009, 05:47 PM   #4
Drywall contractor
Understand, not my #1 choice either. I replaced my treated "cap" with composite after it dried. shrank, warped.......
Old 11-19-2009, 09:22 PM   #5
What is the length of the ridge board? 12' or 16'? What is the dead load of the roof decking, materials? You don't have your location posted, so no-one knows if snow load has to be calculated. Will there be rafter ties, or ceiling joists to tie the rafters together? You need to answer all of these questions.
Telechargement sonnerie portable gratuit gms | Sonnerie portable pour mobile telephone musique | Sonneries portables gratuites mp3 hifi
cartonto is offline   Reply With Quote
Old 11-20-2009, 03:53 PM   #6
Household Handyman
Rewards Points: 1,408
IF you're talking hand rail cap, there are some very nice vinyl hand rail caps out there now. You may have to find a fencing company for these, as in my area. David
Old 11-20-2009, 04:06 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,626
Ayuh,.... The Best way to stop the wood from rotting out is use Steel....
Or aluminum,...
Or ssteel...
Bondo is online now   Reply With Quote
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
joist sistering norriselijah@yahoo.com Building & Construction 9 09-24-2008 09:18 PM
Wood trims in Bathroom, wood or non-wood dbbyleo Carpentry 3 05-05-2008 10:47 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
questions about wood shake roof oraph Roofing/Siding 4 10-26-2006 05:10 AM
