Correct Header Placement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2010, 02:26 PM   #1
Correct header placement
I am in construction, but not a framer. I am building a garage and I'm wondering about the correct header placment in the framing of a 3ft man door and 4ftx3ft window opening. Can I install the header directly under the bottom top plate and fame down to my opening sizes, or do I frame down first and then install the header. What's the difference.
Garage Guy is offline   Reply With Quote
Old 08-28-2010, 02:54 PM   #2
KemoSabe
loneframer's Avatar
It can be done either way. Most important is that everything fits tightly and you have proper jack studs under the header.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
Willie T (08-28-2010)
Old 08-28-2010, 03:03 PM   #3
If I choose to frame down from the header, should I use one more jack stud, split at the 2x that will frame out the top of the opening?
Old 08-28-2010, 03:15 PM   #4
KemoSabe
loneframer's Avatar
It's not necessary. As long as you have the proper jacks under the header, the frame down is not structural. When I do them this way, I like to use a double 2x at the top of the opening. Probably overkill, but I like having the flexibility in the opening, should I decide to raise the door sill for one reason or another. I generally like to line up the window trim with the door trim if they are near each other as well. Having some room to fudge the heights is never a bad thing.
The Following 2 Users Say Thank You to loneframer For This Useful Post:
Garage Guy (08-28-2010), Willie T (08-28-2010)
Old 08-28-2010, 03:44 PM   #5
Thanks for the info.
Much Appreciated.
Framing for Header in Basement Red Truck Remodeling 7 03-18-2010 09:11 PM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 10:13 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 04:20 PM
correct window framing? incorrect header jingles63 Building & Construction 2 05-02-2009 02:49 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
