Closed Thread
Old 07-29-2009, 01:35 PM   #1
Default Correct Beam Size
Hello,
I have some concern about an existing beam we have on our covered patio. There is a span of 16 feet, achieved with a rough 6x6 beam of some kind. It is set on 6x6 posts. The 4 foot patio overhang is comprised of the same rough wood in 4x4's, 24 inches OC, with plywood + regular asphalt shingles. The span just looks very wide me and has less than one inch of sag in the center. We live in CA and the roof has nothing other than leaves on it in the fall. I would like to replace the beam and keep the existing span but the bottom of the beam is pretty low as it is...which is why I am guessing he went with a 6x6.
Have I provided enough info above to determine what size is appropriate...6x8,6x10,6x12?...Thank you! Height clearance is a concern...so I am really looking for the lowest profile...input on wood selection would be appreciated.
Thank you,
ericw1 is offline
Old 07-29-2009, 01:46 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
Hi,
you have opened 3 threads on the same subject
It is best to keep only 1 thread going with the information needed
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is offline
Closed Thread
More On This Topic
Build a Gazebo Conclusion
Build a Gazebo Conclusion by Expert Village
Hi! Welcome back to Expert Village. My name is Charlie Folkman and today we are going to continue building our gazebo. Okay so through the span of the day, the first thing we did was we looked up all the information we needed about building a gazebo on... Read More »
Learn tips on how to write 'roof beam' with the Chinese Radical of wood in this free video clip on Chinese characters and foreign languages. Read More »
In order to make your patio really seem like a part of your house rather just an area outside, you should connect the overhead to the house. Doing so will let you go onto the patio without even getting wet while it's raining. Read More »
After deciding to build a patio, the next step in the process is to decide where the patio should go. Drawing a patio site plan will allow you to first map out your desired location and keep a record of this location for future purposes. Read More »
Having a great ATV and 4x4 truck is cool. Not only can it go off-road, but it can become a statement. However, you should take some steps to make certain your 4x4 truck or ATV remains safe. Here are some tips to remember. Read More »
Beam Size Wildie Building & Construction 22 09-18-2008 10:35 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 10:46 PM
Beam Size sevver Carpentry 16 04-30-2008 02:51 PM
Remove Load Bearing Wall Beneath Hanging Beam cnaildrivenail Remodeling 0 04-29-2008 01:06 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
