Corners With Drywall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-07-2006, 07:52 AM   #1
Corners with drywall?
I am a retired carpenter and have done lots of work on both new and older homes. I am now renovating an old farmhouse that has been in our family for 105 years. (I was born here!) I have done lots of drywall hanging and some finishing, but I havn't done any round walls. I have a round corner (about a 2' radius) that my grandfather built in the house and want to preserve it. What is the best way to drywall around this corner? Thanks, Ol'Luke
Ol' Luke is offline   Reply With Quote
Old 11-07-2006, 07:15 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
My first question would have to be:
Are you asking about 'going over' the rounded corner with new sheetrock and then coating it with compound?...
Or area you talking about re-coating the existing walls with compound?
Please clarify....thanks
- Build Well -
Old 11-07-2006, 08:51 PM   #3
Yes, I need to apply new sheetrock and finish it. The original was plaster, badly deteriorated, and now removed. The challenge is getting a board to bend around the curve. Thanks, Ol'Luke
Old 11-07-2006, 09:26 PM   #4
Darylh's Avatar
we used to use 1/4" drywall and wet the back then srew it on top to bottom as you move along the board..
Darylh is offline   Reply With Quote
Old 11-07-2006, 11:08 PM   #5
Yes, thought of trying that, but hoped there might be something easier.
Thanks!
Old 11-08-2006, 09:53 AM   #6
Purchase Plastic rounded corner bead.
Check with a local wallboard materials supply company.
This is the proper way to do rounded corners. We have done alot of these.
If you have a hard time locating this, try doing an online search and purchase it direct from a supplier.
What you do is:
Hang the sheetrock as normal and install the rounded corner bead as you would normal corner bead and tape it....
- Build Well -
Old 11-08-2006, 10:17 AM   #7
What you do is:
Thanks for the reply! However, I am not talking about a beaded corner. I',m talking about a curved corner with about a 2-foot radius.
Thanks, Ol'Luke
Old 11-08-2006, 10:46 AM   #8
Darylh's Avatar
Another thought came to mind and that is some kind of 1/4" hard board, MDF or whatever.
Old 11-08-2006, 06:18 PM   #9
Thanks, Ol'Luke
Ooohhh, sorry I read it and thought you had written 2"...
Anyhow, this is what to do:
Get a paint roller and bucket or paint tray of water.
Get 1/4" sheetrock: Use 2 layers of 1/4" S/R to match the 1/2" S/R used on your regular walls.
Take 1 sheet and roll the 'moistened' roller over the areas to be 'bent' into a curve. Make sure that you get plenty of water on the sheet's paper (using the MOISTENED paint roller) before you try and bend it. You will have to roll the moistened paint roller several times over the S/R for a period of about 5 - 15 minutes...Don't over soak it....
If it is difficult to get it to keep it's shape, you can wet it, bend it, then keep it formed to the shape you need 'overnight'. Use something to help it keep it's new form. You could use a saw horse and something to keep it from straightening out on the ends.
Do the 2nd layer of 1/4 " S/R the same way...
We have down alot of curved ceilings and walls this way.
Good Luck.
- Build Well -
Old 11-09-2006, 06:17 AM   #10
Alright! Thanks guys! I believe I now have the solution to this part of my challenging project. Ol' Luke
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
