Old 02-05-2011, 08:46 PM   #1
Corner shower grouting
We had a tile corner shower installed in July of 2010. The grout corners continue to crack. We have re-grouted 3 times, but the grout continues to crack. We do not know what to do, short of tearing the shower out and starting again. A new wood frame was installed along with new wall board and all new tile.
jbiskup is offline   Reply With Quote
Old 02-05-2011, 09:48 PM   #2
Use grout caulking in that corner they should have the same color as the grout you used, it's flexible & it look exactly as your grout
Alcarte is offline   Reply With Quote
The Following 2 Users Say Thank You to Alcarte For This Useful Post:
Cmudr1 (02-05-2011), MBatson (02-06-2011)
Old 02-06-2011, 09:00 AM   #3
You can also use a 100% silicone caulking. I think it grabs better and has greater flexibility then the grout caulks. Main issue is the limited color choices.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
oh'mike (02-06-2011)
Old 02-06-2011, 11:06 AM   #4
Always happens unless you use a flexible additive mixed with the grout.
EHouse is offline   Reply With Quote
Old 02-06-2011, 12:38 PM   #5
Builder/Remodeler
ChrWright's Avatar
Inside corners and material transitions should always have a flexible sealant "movement" joint.
As suggested, I would lean toward a 100% silicone sealant that is color matched to your grout. There are a few companies who make acrylic color matching caulks but these do not hold up to the heat in a shower.
Rather than simply going over the cracked grout with caulk, I highly recommend you scrape the grout out of the corner completely first. You'll have a much better looking, longer lasting joint that way.
Christopher Wright, WrightWorks, LLC
ChrWright is offline   Reply With Quote
The Following User Says Thank You to ChrWright For This Useful Post:
fungku (02-06-2011)
Old 02-06-2011, 01:45 PM   #6
Contractor - Renovations
fungku's Avatar
especially if one (or more) of your walls is an exterior wall.
fungku is offline   Reply With Quote
Old 02-08-2011, 10:09 AM   #7
Thank you for all of the information. Does the caulk need to be pushed back into the corner to fill up all the space like the grout was?
Old 02-08-2011, 10:12 AM   #8
Experienced
Jackofall1's Avatar
Yes a good caulk job will fill the void and not just lie on the surface.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
jbiskup (02-08-2011)
Old 02-08-2011, 10:43 AM   #9
I am doing the same job in my shower right now and about to start the tile work. was wondering if you are using an epoxy mix grout or a regular grout. Does this make a difference? We plan to use the epoxy mix.
adventurefamily is offline   Reply With Quote
Old 02-08-2011, 11:10 AM   #10
Super Moderator
You will still want to silicone caulk the corner.
Old 02-10-2011, 12:25 PM   #11
We used a polymer sand grout but it cracked in the corners. We are going to re-do the corner with a silicone caulk
Old 02-27-2011, 02:57 PM   #12
Epoxy is stronger that regular grout. And it doesn't stain easily. But it is very hard to work with and for me does not worth it. I prefer to caulk and seal everything. And take care of it regulary.
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Vertical corner joints cracking in shower stubits Tiling, ceramics, marble 2 02-07-2010 01:46 PM
corner tile shower jimmy21 Plumbing 2 05-25-2009 11:12 AM
cracking corner of newly tiled shower stall jmuamy General Discussion 10 04-14-2009 09:38 AM
Who makes a good corner shower??? murray59 Plumbing 3 06-03-2008 03:26 PM
