-   -   Corner shower grouting (http://www.diychatroom.com/f19/corner-shower-grouting-94652/)
jbiskup 02-05-2011 08:46 PM
We had a tile corner shower installed in July of 2010. The grout corners continue to crack. We have re-grouted 3 times, but the grout continues to crack. We do not know what to do, short of tearing the shower out and starting again. A new wood frame was installed along with new wall board and all new tile.
Alcarte 02-05-2011 09:48 PM
Use grout caulking in that corner they should have the same color as the grout you used, it's flexible & it look exactly as your grout
Ron6519 02-06-2011 09:00 AM
You can also use a 100% silicone caulking. I think it grabs better and has greater flexibility then the grout caulks. Main issue is the limited color choices.
Ron
EHouse 02-06-2011 11:06 AM
Always happens unless you use a flexible additive mixed with the grout.
ChrWright 02-06-2011 12:38 PM
Inside corners and material transitions should always have a flexible sealant "movement" joint.
As suggested, I would lean toward a 100% silicone sealant that is color matched to your grout. There are a few companies who make acrylic color matching caulks but these do not hold up to the heat in a shower.
Rather than simply going over the cracked grout with caulk, I highly recommend you scrape the grout out of the corner completely first. You'll have a much better looking, longer lasting joint that way.
fungku 02-06-2011 01:45 PM
especially if one (or more) of your walls is an exterior wall.
jbiskup 02-08-2011 10:09 AM
Thank you for all of the information. Does the caulk need to be pushed back into the corner to fill up all the space like the grout was?
Jackofall1 02-08-2011 10:12 AM
Yes a good caulk job will fill the void and not just lie on the surface.
Mark
adventurefamily 02-08-2011 10:43 AM
what kind of grout are you using?
I am doing the same job in my shower right now and about to start the tile work. was wondering if you are using an epoxy mix grout or a regular grout. Does this make a difference? We plan to use the epoxy mix.
oh'mike 02-08-2011 11:10 AM
You will still want to silicone caulk the corner.
jbiskup 02-10-2011 12:25 PM
We used a polymer sand grout but it cracked in the corners. We are going to re-do the corner with a silicone caulk
EHouse 02-27-2011 02:57 PM
Epoxy is stronger that regular grout. And it doesn't stain easily. But it is very hard to work with and for me does not worth it. I prefer to caulk and seal everything. And take care of it regulary.
