Old 04-09-2011, 12:01 PM   #16
Corner shed Roof???
yep it's all the same thing. Hip rafters from the corners of your walls to a common point.[IMG]file:///C:/Users/craig/AppData/Local/Temp/moz-screenshot.png[/IMG]
craig4 is offline   Reply With Quote
Old 04-09-2011, 12:04 PM   #17
bigbearz's Avatar
Corner shed Roof???
So the center is just a meeting of all the corners? how do you join them? and the real dumb newbie question is how do you figure all the angles out? is there an easy trick to this?
bigbearz is offline   Reply With Quote
Old 04-09-2011, 12:53 PM   #18
Corner shed Roof???
easiest way. Do you have any builder friends, friends of friends?
A turret roof only works with equal sides. the more I look at your pic the more of a pain in the ass this is. The only way to do a true turret and maintain a level soffit is to change the distance the soffit is off the walls. I.E. 2' at the back and 1' at the front. The roof would also "lean" to the back. The other way is to build a hip off the back corner and a gable across the 2 10' sides. Then you could build a 2 hip roof off the gable to the front wall.
sorry a gable CONNECTING the 2 10' sides, corner to corner
Old 04-09-2011, 01:07 PM   #19
bigbearz's Avatar
Corner shed Roof???
have I got my walls to long at the sides? I wish I could just find a book on these darn things... would make it easier i think, but I have not found any...
Old 04-09-2011, 01:09 PM   #20
Corner shed Roof???
give me a bit. I'm trying to draw something up. the shed is fine just hard to put a roof on.
Old 04-09-2011, 01:11 PM   #21
bigbearz's Avatar
Corner shed Roof???
thanks Craig4... you are the man.
Old 04-09-2011, 01:37 PM   #22
KemoSabe
loneframer's Avatar
Corner shed Roof???
The easiest way to figure out your rafter runs is to snap the roof out full scale on a flat surface, big enough to include your overhangs. The soffit can be kept level and equal overhangs by adjusting the heal cuts at the plate line.
Look at my first pic in my original post. The main porch roof is under a 4/12, while the cone is a 12/12, if memory serves me.
The soffits are level and equal overhangs.
Here's a few framing/finish pics from different projects.
Nothing is impossible, but it may be impractical.
Corner shed Roof???-008-3-.jpg   Corner shed Roof???-013-2-.jpg   Corner shed Roof???-014-3-.jpg   Corner shed Roof???-123.jpg   Corner shed Roof???-020.jpg
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 04-09-2011, 01:45 PM   #23
bigbearz's Avatar
Corner shed Roof???
some nice work there Loneframer..
I have drove through neighborhoods lately in the newer communities and seen a lot of these out there.. just haven't seen one that I can look at inside.... Guess I could ring some door bells and ask... then run when they call the cops..
The Following User Says Thank You to bigbearz For This Useful Post:
loneframer (04-09-2011)
Old 04-09-2011, 03:28 PM   #24
Corner shed Roof???
this should give you an idea how it will work. if you give me the exact exterior dimensions. I can give you the exact hip sizes.Corner shed Roof???-shed-roof.jpg
Old 04-09-2011, 03:30 PM   #25
Corner shed Roof???
oops it's upside down. here is a pic probably upside down as well
nope not upside down
Old 04-09-2011, 03:34 PM   #26
bigbearz's Avatar
Corner shed Roof???
Originally Posted by craig4 View Post
this should give you an idea how it will work. if you give me the exact exterior dimensions. I can give you the exact hip sizes.Attachment 31788
Thats awesome man... it will be 10ft across both backs and 6 on the other 2 then whatever that leaves as the front... i think this is sufficient enough and more room but less yard taken up than using a 8 x 10ft standard shed. if I'm out to lunch let me know...
again thanks man.. thats awesome having help like this from you.
Old 04-09-2011, 03:41 PM   #27
Corner shed Roof???
2x4 walls or 2x6?
O.K. these are the numbers based on 2x4 walls, they are fine vancouver builds 3 storey buildings with 2x4. warmer= less need for insulation
all the numbers are to the center of the cut if you want to go single hips or the center of doubles. I would go 2 plys. 4/12 is flat for a hip roof in Alberta.
The hip cuts are 13.33 degrees the rafters to fill in the hips are 18.43 degrees. I have to go clean my pool now the wife is all over me. I'll check back around dinner to see if you need anything else.
Old 04-09-2011, 04:02 PM   #28
bigbearz's Avatar
Corner shed Roof???
2 x 4... dont think I need to go any bigger... just a shed right.
Old 04-09-2011, 04:18 PM   #29
KemoSabe
loneframer's Avatar
Corner shed Roof???
Those drawings are cool, but I don't see why those three hips don't join in the middle, then run bastard hips on the 45 walls to join at the peak. The plane over top of the door will be a slightly steeper pitch than the rest, but it eliminates a bunch of extra framing.
That looks like a lot of unnecessary work and very difficult to pull off structurally.
Old 04-09-2011, 04:27 PM   #30
KemoSabe
loneframer's Avatar
Corner shed Roof???
oops my bad
Shed roof addition & insulation qustion radgumbo Roofing 2 12-06-2010 06:33 AM
New Shed, Gable Roof papageek Building & Construction 7 10-19-2010 11:11 AM
Attaching Porch shed roof to Brick Veneer ApexTiger Building & Construction 46 02-16-2010 06:28 PM
Question: Altering One Side of a Gable Roof to a Shed Roof willcmjr Roofing 11 09-17-2009 05:32 PM
Flat or shed roof Lonicera Building & Construction 2 12-23-2005 03:56 PM
