Corner Concrete Block Washed Away - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2011, 03:32 PM   #1
I live in Minnesota. Due to a poorly placed (and too long ignored) downspout, I have a corner block of my garage that has appeared to have washed away. Downspout has been relocated, but asphalt driveway apron needs replacement and damage is now obvious. The corner is away from the house. No other damage is obvious.
I'm going to tear out the asphalt apron and have a cement apron put in. The concrete guy says not to bother replacing the block and just to fill with concrete when the apron is poured. Does this plan sound reasonable? Seems ok to me, but I'd feel more confident knowing what others in the industry think. There is no other apparent settling or no damage to the garage slab itself.
Thanks for any input!
RetroActv is offline   Reply With Quote
Old 06-16-2011, 05:16 PM   #2
Rewards Points: 1,092
It's hard to imagine a concrete block just washing away, at 40 or so lbs, and no other damage. Do you think it eroded? Got loose and a previous owner just hauled it out? This is interesting. Any photos?
Old 06-16-2011, 10:09 PM   #3
Concrete & Masonry
Rewards Points: 526
It sounds like it eroded from both the water, as well as the freeze-thaw conditions present. It's a fairly common situation around here. I'd warn against letting the concrete be poured and interlocked into the garage foundation if it has full 4' frost protection depth.
jomama45 is online now   Reply With Quote
Old 06-17-2011, 05:52 AM   #4
Rewards Points: 4,532
not uncommon if its due to excessive soil acid attack
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Older Concrete Block House Painting GreySeal Painting 0 05-06-2011 08:26 PM
concrete block detached building, minimum space between openings rich624 Building & Construction 2 11-22-2010 08:48 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 04:55 PM
Hardiebacker frame....nail into mortar or concrete Block ?? Dyoung Building & Construction 0 02-22-2010 06:38 PM
