Old 01-23-2008, 10:33 AM   #1
yummy mummy's Avatar
Corner Bead....Metal or Plastic?
Soon, I will be installing the corner bead in my basement reno. and was wondering if the plastic or the metal would be better to use.
What are the advantages of one over the other.
Also, can you but two corner beads together if they are not long enough?
Three months later and I'm finished installing the ceiling.
yummy mummy is offline   Reply With Quote
Old 01-23-2008, 05:50 PM   #2
I prefere plastic myself, a little easier to work with. Yes you can butt two peices together
ponch37300 is offline   Reply With Quote
Old 01-23-2008, 06:11 PM   #3
I prefer metal on any straight beads, plastic on radius.
Best if you use a "hot mud" (durobond setting type) for the first and second coats, this will give a strong corner w/o drying cracks, and you can do both coats the same day.
Sure you can join 2 beads. I use a 3x5 piece of aluminum flashing folded @ 90 degree angle under the seamto keep them lined up. Make sure you don't have any burrs on the ends, if so, a little filing will do well.
gl
cnydave is offline   Reply With Quote
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 04:25 PM
Flexible metal corner bead? Worth using? yummy mummy Building & Construction 3 11-15-2007 07:09 PM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 09:20 AM
