Converting An Old Grainery To A Hunting Cabin - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 07:32 PM   #1
Converting an old grainery to a hunting cabin
Hi,
The family farm in Door County, WI has a 100+ year old grainery I am looking to convert into a hunting shack. The grainery has never had heat to it. The stone foundation is crumbled enough to allow 2-3' free air flow under the grainery. We plan on starting by sanding the oak plank floors and finishing them, closing up any drafts and replacing/adding windows. We are then going to add a wood burning stove for heat. Among many concerns, should I be worried about the new weatherization of the old building and the introduction of heat? There will be a small upstairs for sleeping accomodations with 3-4' sidewalls and a 7' peak, with an opening in the floor to allow heat up.
Any thoughts or help would be appreciated.
Thanks!
LukMic is offline   Reply With Quote
Old 06-13-2011, 07:52 PM   #2
DIY staff
Rewards Points: 7,174
You should be able to close that space in----Do you have any pictures? that will help.
Getting some insulation into the place will help---Mice proofing it will be a challenge.---Mike---
Old 06-13-2011, 08:32 PM   #3
I will have photos in the upcoming weeks. Thanks for the reply. Insulation is in phase II. Phase I is cold...
Old 06-13-2011, 08:40 PM   #4
DIY staff
One of my best friends live in Green Bay-----He lives to hunt----and he's handy with tools!
Give me the word and I'll hook you up.
He holds several state championship skeet shooting records. ---Mike---
Old 06-14-2011, 09:13 PM   #5
A wood burning stove is great heat, but add an air intake pipe to furnace area so that cold outside air is used for combustion, and not the warmer room air.
Also add (it's cheap) a heat manifold/blower that will circulate warm air from around the stove itself and distribute it further away.
If you're away from powerlines you can do it pretty cheaply with a 12 or 24 volt deep cycle battery. Your choice for electrical charging of the battery: PV or a small wind generator.
Garrett
GarrettP1 is offline   Reply With Quote
log cabin roof framing sixpicks Carpentry 0 05-18-2011 05:02 PM
BIG PROBLEMS with cabin mud sills and floor scylla2 Building & Construction 1 10-18-2009 08:34 PM
Beginner decide Laminate vs vinyl squares in 10x28 backyard cabin? tdg8934 Flooring 3 12-15-2008 05:51 AM
Can I set a cabin on top of mobile home slab? birchbarx Building & Construction 4 03-22-2008 06:06 PM
Reinforcing cabin Gami Building & Construction 4 11-30-2007 07:22 AM
