Converting My Garage From A 2 Door To A Single Door. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2013, 02:59 PM   #1
Rewards Points: 260
Converting my garage from a 2 door to a single door.
Hi all. I have a 20'x20' garage with a hip roof that is current a 2 door. I want to convert it to a single door, but had a question about the header. Right now, the header is 2 2x8x20 pine sistered together, but since it's a 2 door, it has a support in the middle of the span. Obviously since I want to convert it to a single door, I'll need to take out the middle support, but how do I know what would be the appropriate header to replace it with? I was thinking of using 2 2x8x20 LVL, but wasn't sure if this would be strong enough. Can anyone on here help me out? Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 05-19-2013, 03:05 PM   #2
Jesse
If it's roof load only, it simplifies things. Still, the answer changes based on the material you want to use. For an example, let's look at Southern Yellow Pine. You reference the document with the support information, and match it to your scenario.
See this PDF page 8. http://www.southernpine.com/pdf/ref207.pdf
Edit: Actually, it doesn't even have 20' clear opening as an option, so then you'd have to be getting into steel or LVLs (laminated veneer lumber). That's an awfully big distance to span.
ModernDayDarwin is offline   Reply With Quote
Old 05-19-2013, 03:22 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
what is the width of the single door?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-19-2013, 03:24 PM   #4
Rewards Points: 260
Well my clear opening will only be 16' and according to the PDF, a 20' supported roof framing (the garage is 20x20). So according to the table, with a 16' clear opening and a 20' span of supported roof framing, the header would require 3 2x12 No. 1 grade southern pine. However, how can the header be "3" 2x12s? The tops of the 2x4s that the ends of the header would rest on would be too narrow (a 2x4 is only 3 1/2" wide). 3 2x12s would be 4 1/2" thick? What if I used 2 2x12 LVL?
Jesse
Old 05-19-2013, 03:25 PM   #5
Rewards Points: 260
The width of the new door is 16'.
Old 05-19-2013, 03:36 PM   #6
GBrackins's Avatar
go into your local lumber yard and ask them to size the header to your code required loading. I know the yards in my area can do that, though sometimes they have to send it out to their engineer.
Gary
Old 05-20-2013, 12:03 AM   #7
Rewards Points: 1,016
I converted two doors one once - easiest with the least surgery and lack of clearance was to go with a steel header.
____________
Vince
Old 05-21-2013, 10:48 PM   #8
Rewards Points: 260
Called my local lumber yard and they hooked me up. Thanks so much!
Jesse
Old 05-21-2013, 11:22 PM   #9
GBrackins's Avatar
glad to hear it worked out for you ..... post some photos when you're done please
Gary
Old 05-22-2013, 12:22 AM   #10
Rewards Points: 260
Will do. Thanks!
Old 03-17-2014, 02:29 PM   #11
Rewards Points: 260
Hey guys. I know it's been a while, but I completed my garage door conversion project and I also just finished putting up a wall made from recycled fence planks. It's my sisters old privacy fence now converted into a beautiful rustic interior wall. Very cheap, but labor intensive.
Converting my garage from a 2 door to a single door.-forumrunner_20140317_142313.jpg
Converting my garage from a 2 door to a single door.-forumrunner_20140317_142328.jpg
Converting my garage from a 2 door to a single door.-forumrunner_20140317_142351.jpg
Converting my garage from a 2 door to a single door.-forumrunner_20140317_142420.jpg
Converting my garage from a 2 door to a single door.-forumrunner_20140317_142440.jpg
Converting my garage from a 2 door to a single door.-forumrunner_20140317_142531.jpg
Converting my garage from a 2 door to a single door.-forumrunner_20140317_142807.jpg
Old 03-17-2014, 08:03 PM   #12
iminaquagmire's Avatar
Rewards Points: 338
Glad you found help. The wall looks good but if that's against interior living space, you've removed the fire rated wall assembly for an un air sealed now flammable wall.
iminaquagmire is offline   Reply With Quote
Old 03-17-2014, 09:14 PM   #13
Concrete & Masonry
Rewards Points: 530
Maybe you missed the picture, but there's a window with sun shining into it in the picture. Highly unlikely it's an interior wall.............
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
iminaquagmire (03-18-2014)
Old 03-18-2014, 07:57 AM   #14
Rewards Points: 53
Looks like you have a low headroom kit installed on your garage door. May I ask if it was difficult to install?
Don't mean to hijack.
pc9460 is offline   Reply With Quote
Old 03-18-2014, 09:28 AM   #15
Rewards Points: 260
The garage is detached from the house and I paid to have the garage door installed.
garage door won't go down Kela82 Building & Construction 7 02-21-2013 12:16 AM
Garage door framing stevekem Building & Construction 12 11-02-2012 08:53 AM
Garage Door Opener Help jwysocki General DIY Discussions 1 04-10-2011 05:28 PM
Garage Door Repair Tip doortodoor Windows and Doors 0 03-15-2011 09:05 AM
Moving interior door to garage - awkward? violetUK Building & Construction 3 12-05-2009 10:40 AM
