Converting A Closed Porch To An Open Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 04:28 PM   #1
Converting a closed porch to an open porch
I have a seasonal room that I don't use (was initially meant to be a porch then enclosed, only has one vent to heat/cool) and would like to convert into an open covered porch. The room is on a concrete foundation with storm windows and a slanted ceiling. this is a large house with no exterior porch with shade. I can install a sliding glass door from living room to this room. My question is, how to insulate the soon to be exterior walls? Also what to do with the ceiling tiles? change them to be more outdoor friendly. This room is about 14 X 18.
taycop is offline   Reply With Quote
Old 07-27-2011, 06:07 PM   #2
Rewards Points: 5,336
I would think the walls were already insulated from your description. You can check by either removing an outlet cover or baseboard molding and looking behind the sheetrock.
What do you mean by ceiling tiles? Dropped ceiling or staple up on a grid? If it's a dropped ceiling, put in the plastic covered fiberglass tiles.
If it's the staple up material, you can replace it with a wood beadboard or just try to put a few coats of exterior paint and see how they hold up.
B. Franklin 1759
Old 07-28-2011, 10:13 AM   #3
converting porch
The ceiling tiles are those that are stapled to the ceiling. bead board might work and I like the idea of painting with exterior paint - to seal it. I did look and there is insulation I think that if I use some foam board then put up either siding or something it should work. Thanks for the suggestions.
Fresh air intake damper - Open or Closed? dtran HVAC 7 01-06-2009 05:30 AM
Converting an open staircase to a "closed" staircase? tony1853 Building & Construction 7 01-05-2009 01:55 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
garage door open light deck hand Electrical 3 01-22-2008 08:29 AM
