Converting Carport To Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2009, 02:09 PM   #1
converting carport to garage
my thing is that the previous owner of the house had a cement slab installed because he intended to close the carport but never did. we were told we needed a sort of a cement foundation to build up the side walls. how do we proceed in doing this on this previous slab...with cement block or get someone to pour a cement wall about 1 1/2 foot high
nruest is offline   Reply With Quote
Old 04-16-2009, 04:11 PM   #2
Rewards Points: 5,336
If the slab was code poured, you can do either. I would install a rebar system to connect the two concrete units. Also install anchor bolts to hold the pressure treated sill plate to the top of the wall.
Ron
Old 04-16-2009, 08:10 PM   #3
CrossWorks's Avatar
Rewards Points: 150
There are a lot variables here to consider.
  • Does your slab have reinforced wire mesh?
  • How thick is your slab?
  • You'll need to form a 8' wide by 12" high concrete wall around the entire perimeter excluding doorways, and your slab will need to be thick enough to not only support the cement, but also the wall framing, sheething, siding and roof load as well.
Without being there, it's a challange to steer you in the right direction here. How about some pictures? The cement wall is to prevent any water from seeping in.
I would highly suggest getting a contractor out there to assess the situation. Find someone who you know has extensive experience (hopefully a friend or acqaintance). I know that's a foregone conclusion, but I think it's the wisest approach in this case.
Reason being, hopefully whoever poured the slab, they formed it properly to have the carport inclosed in the future. If anything, the posts that support the roof most likely have a pier underneath going down to a depth according to code for your area, and the slab should be at a the thickness according to code as well. (maybe 6-8"'s) and IS reinforced to support the weight of the vehicles. Considering that the slab was poured after the house was built, I highly question if it was done properly. That's just my "gut feeling".
In any event. most contractor's are willing to go out and give you an estimate. Give that a try.
Good Luck
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-16-2009, 08:12 PM   #4
Where are you located?
Frost/freeze depth?
Old 04-29-2009, 02:01 AM   #5
I had a similar problem. My friend suggested me http://www.classiccarports.com/ . They did an excellent job of converting our carport to garage in no time. These guys are experts in offering all sorts of carport services and other metal structures. Try and at least find the estimates. Perhaps they can prove helpful.
timanderson is offline   Reply With Quote
Old 04-29-2009, 08:18 AM   #6
Tim, post a picture of your job, it might help.
This seems to be spam, Timmy.
Ron
Converting carport to Garage 53buick Building & Construction 2 03-15-2009 05:17 PM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 05:18 PM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
Converting Carport to Garage - $25k or $45k Todd1 Remodeling 5 07-19-2007 12:57 AM
Framing a carport on a detached garage nomagic Carpentry 3 05-04-2006 11:43 PM
