Old 02-19-2011, 04:07 PM   #1
are control joints needed
building a slump block fence 150 ft long by 6ft high do i need control joints if so can i go every 24 ft
wayne beresford is offline   Reply With Quote
Old 02-19-2011, 09:01 PM   #2
Carpenter
dtsman's Avatar
This page gives you the specs. See table #1 and the paragraph under it. It is all proportional to the height. So, the answer is yes, you need control joints, but it all depends on your area of the country and the size of the wall.
Hope this helps.
http://www.masonrymagazine.com/3-03/controljoints.html
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Water heater control valve only works if I bang it papashaq Plumbing 1 01-07-2011 03:32 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Air Source Heat Pump Lock-Out Control sydneysm HVAC 7 11-11-2010 05:58 PM
Filling/covering control joints while laying tile on concrete Marita Tiling, ceramics, marble 0 09-19-2010 02:46 PM
Concrete - Control Joints AndrewF Building & Construction 10 08-09-2009 03:42 PM
