Contractor Installing Hardiplank - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 09:51 AM   #1
I have a contractor currently replacing our cardboard (practically) siding with Hardiplank. He is intalling the new siding directly to the studs after attaching the Dupont barrier.
Should there also be plywood or some other supportive barrier? We live near Houston, Texas so heat, humidity and critters are a concern.
Thanks in advance!
Blessings!
Shari
ShariH is offline   Reply With Quote
Old 04-26-2011, 11:27 AM   #2
Next Time...New Build
Rewards Points: 150
I can only speak for my northeast experience, but all siding I have ever installed, including Hardiplank, has been over exterior sheathing. I would not want the plank to span the stud cavities without something solid behind it. That stuff is way too flexible IMO to do that.
Not sure what the mfg instructions state, but seems to me that there should be some backer for installation. One of the pro siders should be along to help you out better.
RickyBobby is offline   Reply With Quote
The Following User Says Thank You to RickyBobby For This Useful Post:
rossfingal (04-26-2011)
Old 04-26-2011, 03:47 PM   #3
Rewards Points: 2,240
Do not install the siding directly over the studs!!!!!!!
Any siding!
rossfingal
rossfingal is offline   Reply With Quote
Old 04-26-2011, 03:51 PM   #4
Check the manufacturer's instructions/warranty info -
It may invalidate the warranty!
(Some type of "house-wrap" is required)
Regards!
rosfingal
Old 04-26-2011, 04:15 PM   #5
siding over sheathing with barrier , how else are the critters supposed to stay out they can eat thru anything
fulton 22175 is offline   Reply With Quote
Old 04-26-2011, 04:20 PM   #6
Yeah, see "critters" (squirrels) eat through .024 aluminum!
(If I hadn't seen it - I would not have believed it!)
rossfingal
Old 04-26-2011, 04:56 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
The sheathing provides structural integrity to the building. It prevent racking and ties all the framing together (the bottom plate to the studs and the studs to the top plate). Stop the job and get the building inspector involved it the contractor is a jerk.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 04-26-2011, 06:09 PM   #8
kwikfishron's Avatar
Rewards Points: 818
Although I strongly disagree with installing Hardi without sheathing but the manufacture allows it.
http://www.jameshardie.com/pdf/insta...eplank-hz5.pdf
kwikfishron is online now   Reply With Quote
Old 04-26-2011, 08:32 PM   #9
Framing Contractor
Thanks in advance!
Blessings!
Shari
This has to be a joke. Unless it's a shed.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-26-2011, 10:17 PM   #10
Registered User
Rewards Points: 526
Fig.301.2(4), halfway down the page.
Appears you are in the 120-130 mph wind Zone here; http://publicecodes.citation.com/ico...001_par004.htm
You should at least be building to this; http://www.awc.org/pdf/WFCM_90-B-Guide.pdf
The existing (hopefully) let-in braces are far to weak for your area, though may be acceptable for local Code, ask your Building Department. http://bct.nrc.umass.edu/index.php/p...n-the-outside/
Perhaps there was shiny cardboard under the siding- called Thermo-ply- it is structural, I stopped installing that in the ‘80’s; http://www.berryplasticsbpg.com/prod...age=thermo-ply
And, welcome to the forum!
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
jagrrr (05-21-2011)
Hardiplank peeling Dona1993 Painting 16 08-13-2016 09:17 AM
hardiplank staining Katherine Painting 11 06-25-2012 02:08 PM
Hardiplank Siding repainting/staining cpharris Painting 1 10-21-2010 01:57 PM
painting hardiplank siding jj1leblanc Painting 2 07-17-2010 09:28 PM
Sealant to use with Hardiplank siding JPGO General DIY Discussions 12 07-16-2010 09:08 PM
