Contractor Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 06:44 PM   #1
Rewards Points: 150
Contractor help
Hi guys, I'm hoping one of yo contractors can help me out with a question I have.
I'm building out a bridal boutique and i need to meet IBC 1210.2 requiring:
"Walls and partitions within 2 feet of urinals and water closets shall have a smooth, hard, non-absorbent surface, to a height of 4 feet...the material used in such walls shall be of a type that is not adversely affected by moisture."
I usually use FRP for this but doesn't look good enough for a boutique restroom. Tile is out of the budget.
My question is, what else meets this requirement? My plumber said he has seen painted wood wainscoting used but I can't believe that would meet the requirements. Then again I don't see how grout meets the requirement.
Any ideas?
Thanks,
Ben
Broughton is offline   Reply With Quote
Old 08-03-2011, 06:50 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The world is full of powder coated sheet metal toilet partitions. What would be wrong with something manufactured for the purpose?
XXX
Old 08-03-2011, 06:55 PM   #3
DIY staff
Rewards Points: 7,174
To bad tile is out of the question---anything cheap looks utilitarian that I've ever seen.
Old 08-03-2011, 07:26 PM   #4
Rewards Points: 150
I like it Bud, I'll look into those.
Oh'Mike, I hear ya. Went high end on the dress racks and lighting so the bathroom gets the left overs.
Thanks guys.
Old 08-03-2011, 07:41 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You think tile is out of the budget !!!???
XXX
Old 08-03-2011, 07:42 PM   #6
Rewards Points: 150
Labor my friend, I'll glue those panels up myself.
Old 08-03-2011, 08:03 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I was thinking about buying the completed assembled panel but I suppose you can buy just coated panel inserts. If that's the case the cost starts plummeting fairly quick.
XXX
Old 08-03-2011, 08:13 PM   #8
Rewards Points: 150
Ah, I see, I just need the thin sheets that glue to the wall, not those big stall dividers.
Also, the owner may or may not be...but definitely happens to also be my wife which means if I do the labor it is much less (read free) than if I bring in one of my guys.
Old 08-04-2011, 06:24 AM   #9
DIY staff
It'll still cost you!
