Contractor Drilled Into Sistered Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-25-2009, 11:11 AM   #1
Contractor drilled into sistered joists
A contractor drilled a heavy bolt dead center between 2 sistered joists that support the staircase above. The bolt was placed there to secure the newel post above the floor. My concern is that he halved our joist and that the staircase above is no longer adequately supported. We've recently been hearing a lot of new creaks along the staircase and at the top of the staircase. Will sistering another joist to the outside of the 2 halved joists work in this case? Or should we place a support beam midway in the joist span? Thanks.
Mel N is offline   Reply With Quote
Old 09-25-2009, 11:31 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Mel... how big a bolt did he drill? Diameter that is.
12penny is offline   Reply With Quote
Old 09-25-2009, 11:40 AM   #3
Old School
Willie T's Avatar
I must be slipping. I couldn't follow that at all.
Willie T
Old 09-25-2009, 12:00 PM   #4
I'm not sure how to attach a photo which would explain better. Each joist is 1.5" wide and sits directly beheath the staircase. The hole drilled to set the newel post is 1.5" wide in circumference and went in between the sistered joists effectively halving them. Thanks.
Old 09-25-2009, 12:02 PM   #5
Household Handyman
Rewards Points: 1,408
Maybe "Wille T" is my age, or we're both slipping. Mel N, with all due respect, could you post a picture or maybe a better description. And as "12penny" asked, what size (diameter) bolt? Thanks , David
Old 09-25-2009, 12:12 PM   #6
Not so new
12penny's Avatar
Rewards Points: 520
Mel.... wouldnt hurt to throw another joist in there. If you cant get in a full length one, go as far as you can and use something like ledger locks or carriage bolts to secure it.
Old 09-25-2009, 12:37 PM   #7
photo attached
Maybe this will help. Thanks again.
Old 09-25-2009, 12:38 PM   #8
Registered User
Rewards Points: 5,482
Holes bored in rafters or ceiling joists shall not be within 2 inches (51 mm) of the top and bottom and their diameter shall not exceed one third the depth og the member.
Obviously, this doesn't pertain. I would put a post or wall under it, on treated mudsill.
Be safe, Gary
Old 09-25-2009, 12:44 PM   #9
Yes, he bored through the entire length of the joist. If I had known what he was doing, I would have stopped him. I'm not in the business but even I know that isn't the way to do it. The question is how do I fix it now? With the wires and plumming, it's more of a project than I feel comfortable with. That's why I was thinking about placing a pressure treated 4 x 4 as a post to give it some support midspan. But is that just a bad idea?
Old 09-25-2009, 12:57 PM   #10
General Contractor
You need to have it evaluated by a structural engineer. There is no need for you to attempt any repair on this. If you hired a legitimate contractor and a repair or alteration is deemed necessary by a structural engineer this should be covered under the contractors GL insurance. If you did not hire a legitimate contractor but rather someone on the side then I wish you the best of luck.
ARI001 is offline   Reply With Quote
Old 09-25-2009, 01:14 PM   #11
Yes, we did hire a legitimate contractor. But as everyone knows, even the good contractors send out the newbie (or subcontractor) who screws up the job. The work was done several years ago and the company has since gone out of business. I am assuming, maybe incorrectly, that you can't sue a company that is out of business. And as to why we didn't resolve it before now, I only just discovered it when I went looking for the cause of the creaks.
Old 09-25-2009, 02:28 PM   #12
Is that an old stairwell with the white trim?
Easiest solution would be to put a post in if there isn't anything underneath preventing that
With the existing wires drilled thru the joists it might be tough to sister another joist in there
Old 09-25-2009, 03:08 PM   #13
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
I wouldn't worry about it. It's already a double and it looks like it's only headed off for the width of the stairs so not a big load on it anyway.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-25-2009, 03:26 PM   #14
Hi Scuba Dave. The white trim is a stair well. The one that I'm standing on. My house is a cape cod. The staircase to the basement is directly under the stairs to the second floor. See photo.
I appreciate your thoughts. Do you think a 4 x 4 pressure treated post is sufficient? It's an 11.5 foot span from the steel I beam support to the foundation. The wall suggestion was a good one as well. But its a tight turn at the base of the steps which doesn't allow much room for things like a furnace, washing machine etc.
Clutchcargo, I don't understand your comment, "it's only headed off for the width of the stairs." Aren't the joists in question supporting the weight of the stairs above them?
Thanks everyone for your thoughts! I'm multitasking today so I may not respond as quickly as needed but I am grateful none the less.
Old 09-25-2009, 03:39 PM   #15
Old School
Willie T's Avatar
I'm pretty sure that would have gotten us red-tagged here.
Willie T
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 06:41 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 12:48 PM
is 2x6 8" OC really better than sistered "4x6" 14" OC mike.MGI Building & Construction 3 11-20-2007 09:55 AM
