Old 05-27-2012, 03:29 AM   #1
continuous strip soffit vents
I need to know if these vents come in more than one width. I need one 6" wide and about 48' of it for my deck ceiling which vents into the attic. I cannot find a product and wonder if there isn't one. Please advise if you know. Thanks.
tigereyes1 is offline   Reply With Quote
Old 05-27-2012, 10:32 AM   #2
Why 6" width?
bob22 is offline   Reply With Quote
Old 05-27-2012, 10:39 AM   #3
AHH, SPANS!!!
you are probably better off getting the 6" black vinyl or copper soffit screen and stapling to the overhang and then box it all out. don't forget to paint the overhang blocks black where the screen crosses them so that you do not see the whitewood later.
hand drive is offline   Reply With Quote
Old 05-27-2012, 12:18 PM   #4
the vent was already there in the OSB and we covered the OSG with T&G pine. We want to cover that space without having to rip varying width boards to bring the T&G to the edge of the existing vent so we need something between 5.5 and 6 inches to completely cover the gap between the T&G on each side of the existing vent.
Old 05-27-2012, 12:35 PM   #5
Post a picture.
I think you mean OSB not OSG.
It would have looked far better and have been 0 maintance to have used beaded vinyl vented soffit and wrapped the fashia with coil stock.
Old 05-27-2012, 12:48 PM   #6
Nothing made that way. When we run it in a t and g soffit we rip the pieces to the right width on those rows. with little blocks cut to size to finish the ends.
Tham
Tham is offline   Reply With Quote
Old 05-28-2012, 01:35 AM   #7
Moderator
I'd use the 2-3/4" wide continuous soffit venting at 9 NFVA per ft. to match the ridge vent. The 4" wide punched soffit is only 4.68NFVA per ft. You'll need 2' deep soffits to get the 9 required.....and it wouldn't be installed close to the fascia board (optimum air pressure location). http://docs.google.com/viewer?a=v&q=...4EyM707m0gPdXQ
Gary
Clothes taking longer to dry?
Old 05-28-2012, 05:03 AM   #8
I have found some soffit vent screen that will work with a wooden trim covering the edges. Now my question is which gauge screen to use; there are many choices - galvanized vs stainless vs copper + different numbers and sizes of holes per linear inch. It comes in a roll and I can order the number of inches/ft I need. Any suggestions in layman's terms about which product to pick?
Old 05-28-2012, 06:51 AM   #9
Moderator
kwikfishron's Avatar
23 gauge galvanized will work fine (stainless steel if you're on the Coast). 1/8"-1/4" on the holes, no bigger than 1/4".
The box stores will have it. If you go to someplace like Ace they will likely sell it by the foot.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 05-28-2012, 11:41 AM   #10
kwikfishron,
thanks so much. I live in northern Idaho - not coast but plenty damp (this year, at least), still galvanized? It will get no direct moisture.
Old 05-28-2012, 12:36 PM   #11
Moderator
Originally Posted by tigereyes1 View Post
kwikfishron,
Galvanized is fine. I only use stainless within 7-10 miles of the Ocean where the salt wreaks havoc on steel.
-NEW MEMBERS-
The Following User Says Thank You to kwikfishron For This Useful Post:
tigereyes1 (05-28-2012)
Old 05-28-2012, 12:40 PM   #12
Thanks, so much. Now that I know what it is; it is the same stuff we used on our ridge vent under our ridge cap and my local building supply has it. Our HD only has 4" so I appreciate your prompt response and assistance.
need advice installing soffit vents in vinyl siding tspoon84 Roofing 4 01-05-2012 10:20 PM
Taking off Soffit Vents to clear insulation Mishof Roofing 15 09-03-2011 05:01 AM
soffit vents federer Roofing 13 08-26-2010 11:44 PM
Attic ventilation without soffit vents jayman9782 Building & Construction 0 06-14-2010 09:26 PM
Soffit vents on older houses with "curved" ceilings Labman101 Roofing 2 02-07-2010 11:33 PM
