Old 10-24-2012, 11:17 AM   #1
Continuous Soffit vents
What is the best location to install a continious soffet vent; near the house wall, as far a s possible from the house wall or midway between?
cemoorhead is offline   Reply With Quote
Old 10-24-2012, 11:27 AM   #2
Down the middle is the only way I've ever seen it done.
Old 10-24-2012, 12:09 PM   #3
747
registered
747's Avatar
Yes down the middle.
747 is offline   Reply With Quote
Old 10-24-2012, 02:20 PM   #4
GBrackins's Avatar
you can purchase soffit board with the strip vent in the middle, or you could install a cornice vent that goes behind the freize board, see this link for more information http://www.cor-a-vent.com/s400.cfm
many different ways of venting the soffit.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-24-2012, 07:30 PM   #5
Framing Contractor
90% of the time I rip a piece of soffit 1-1/2" the thickness of the 2x sub-fascia and start with that up against the back of the fascia. Then butt the soffit vent up to that. I've only put it down the middle on new houses a few times and sometimes on additions to match the existing vent. It's obviously preference.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
mae-ling (10-24-2012)
Old 10-24-2012, 10:35 PM   #6
AHH, SPANS!!!
it depends on the amount of overhang, but 12 to 16" overhangs I always rip the first soffit piece 3" and install before the fascia board goes on. I use a 4 to 5" rip for overhangs greater than 16". A lot of times there is a frieze board and bed mould up under the soffit so the amount of overhang is always reduced down some because of the bed and frieze. I tack only the front edge of the 3" rip to the sub fascia. With the front tacked, the piece has enough tension to hold the vent in place and then with the vent in place,tack the back edge of the soffit piece and up through the vent edge as well. After the front piece is in the back piece goes up last.
hand drive is offline   Reply With Quote
Old 10-25-2012, 12:16 PM   #7
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
I would recommend installing it as far from house wall as possible.
Especially on the sunny sides of the house.
Andy.
Residential Drafter/Designer
AndyGump is offline   Reply With Quote
Old 10-25-2012, 11:42 PM   #8
Moderator
Yep, double louvered, continuous, right next to the fascia board, pp. 616; http://books.google.com/books?id=Z8a...0vents&f=false
Gary
PS. welcome to the forums!
Clothes taking longer to dry?
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing/Siding 18 05-29-2012 10:12 AM
continuous strip soffit vents tigereyes1 Building & Construction 11 05-28-2012 12:40 PM
Ridge Vent with No Soffit Vents? Is it possible? NTL1991 Roofing/Siding 4 05-14-2012 03:08 PM
Hidden Soffit Vents Mucluk Building & Construction 4 01-26-2012 09:15 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
