Container Homes, What Foundations Does It Need?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2010, 05:46 AM   #1
Container homes, what foundations does it need??
Greetings,
I have been scratching my head at what foundations does a container home
need for 2 or maybe 3 containers to be stacked ontop of one another to be
suitable for living in??
Have a look at the pics below, I am really amazed at their beauty and even
large scale builds just with container homes :O !!!!
Container homes, what foundations does it need??-sg-blocks-container-house-1.jpg   Container homes, what foundations does it need??-shipping-hangar-home.jpg   Container homes, what foundations does it need??-container-home-kit-1.jpg
shabba1985 is offline   Reply With Quote
Old 06-25-2010, 10:40 AM   #2
Foundation would depend upon local requirements
Here it is below the frost line 42-48"
Old 06-25-2010, 12:04 PM   #3
Rewards Points: 502
I've been thinking about these quite a bit lately too.
you can go with piers for the easiest way. they are made to be suported by the 4 corners if you keep the structure in tact.
they have the empty weights painted on them. I want to think they weigh a bit over 10,000 lbs for the most part
I don't see a reason why they couldn't be left on a slab or on top of a basement wall either.
forresth is offline   Reply With Quote
Old 06-25-2010, 01:41 PM   #4
kwikfishron's Avatar
Rewards Points: 172
Container swimming pool, do they really do that?
kwikfishron is online now   Reply With Quote
Old 06-25-2010, 01:47 PM   #5
I guess they do !!
Old 06-25-2010, 03:37 PM   #6
Hi, yes I dont see why I couldnt just make it on some kind of a raft
structure, maybe a plinth (square concrete slabs).
http://www.swiftfoundations.co.uk/swift_plinth.php
What is a pier by the way???
Also any other ways to support a double story container structure... but
really I don't see why you could just stick them ontop of one another like
lego.
Old 06-25-2010, 03:54 PM   #7
Originally Posted by Scuba_Dave View Post
I guess they do !!
wow the possibilities all in a tin!! without foundation work??? is that rly true
Old 06-25-2010, 05:36 PM   #8
Household Handyman
Rewards Points: 1,408
The U.S. D.O.D. has multiple contracts now for companies which turn these containers into "apartments" for two (2) servicemen/women stationed at remote post such as Iraq and Afghanistan. Imagine being there and being assigned to live in a big tent, then getting one of these to live in, even with another grunt. I'd call them Heaven if it were me. They come completely wired, plumbed, and furnished. Just set them, hook up wiring, plumbing, etc., and hand over the keys. There stacked two-story high with balconies running the length of ten units with stairways. Not bad for our service people in my opinion. The Officers get single occupied units--of course. David
Old 06-25-2010, 07:21 PM   #9
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by shabba1985 View Post
Greetings,
If you live in an area that has building permits and code requirements, I suspect you might have to have an engineer design a foundation, method of attaching the units together, and possibly even giving an engineers report of the structural strength of the unit itself.
Old 06-26-2010, 12:16 AM   #10
Rewards Points: 502
Also any other ways to support a double story container structure....
a pier is a vertical pole pounded into the ground, often seen with raised structures near (or above) the ocean
The cheapest way would be to put a short wall the width of the container at each end, going down below the frost level the frost wall would have to be strong and the footings very large to hold all that weight without shifting
for a double story;
I was thinking of doing 2x 40' containers spaced apart to make a 40' cube, then repeat but turn the structure 90 degrees the next story up.
This would take care of all the load bearing walls, and leave a big open "courtyard"
I wonder if you could just burry 1 container to make a foundation and basement?
Old 06-26-2010, 03:23 AM   #11
Rewards Points: 1,016
any links to pictures or more information? construction details? Thx!
Old 06-26-2010, 09:17 PM   #12
wouldn't a normal concrete floor be just as good then?
Old 07-04-2010, 12:28 AM   #13
Hi, I am currently stationed in Afghanistan. And there are many 2,3, and even 4 container high 'apartment buildings' here. One of the 2 story 'container buildings' i've watched being built has 8 containers side by side on the first floor and 8 more stacked for the second floor, and the foundation is two footer/concrete wall foundations running the length of the building. The concrete was only under the front two and back two corners. James
jtheissen is offline   Reply With Quote
Old 07-04-2010, 06:13 PM   #14
Rewards Points: 502
I need close to a 4' frost wall here, so normally everyone just does a full basement. I'm thinking contaiers might be cheaper than concrete.
Old 07-04-2010, 06:29 PM   #15
nap
You talking to me?
nap's Avatar
you are still going to need an engineered foundation or an engineers stamp that sticking a box in the ground is in fact an adequate foundation.
the other fact that is getting overlooked is: these containers are designed to support and be supported by the corners only. That means the area in between the corners is not considered to be structural, in terms of supporting the unit. As such, I would doubt an engineer would sign off on just dropping one of these in the ground as you are still effectively supporting any above grade structure by the 4 corners. I would bet they would require a substantial base at each of the corners.
Planning out a shipping container house benlinus Building & Construction 25 03-06-2012 07:19 PM
Underground Container vs. Sewer? gante Plumbing 3 03-18-2009 08:25 PM
Modular Homes? DaManAgain General DIY Discussions 10 01-13-2008 10:17 PM
Foundations SuBScRiPt General DIY Discussions 13 05-25-2005 02:01 PM
