Consturction Adhesive - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 08:46 PM   #1
Consturction adhesive
Can I use construction adhesive to hold framing to block wall permently, or should I use some other type of support.
Crooked nailer is offline   Reply With Quote
Old 09-25-2010, 08:20 AM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
i guess it depends on what the framing is used for.if it is structural you will need fasteners. If it it not load bearing it might be fine. the premium pl400 i find holds very well.
Millertyme is offline   Reply With Quote
Old 09-25-2010, 10:05 PM   #3
Knucklez's Avatar
Rewards Points: 932
PL9000 is awesome. bit its always good to use a couple of screws too if you can because it pulls the wood together for a superior screw/glue combination.
probably not a good idea for load bearing.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Problems with Omni Grip tile adhesive Blue Flooring 24 05-15-2016 07:37 PM
Purchase Planipatch to cover the old adhesive ? jmpkiwi Flooring 1 02-11-2010 07:09 PM
Granite & Adhesive question cody21 Kitchen & Bath Remodeling 3 07-22-2009 05:11 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 07:54 AM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
