Construction Span Distance - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 08:27 AM   #1
Construction span distance
How long span can you have on floor beams on single 2'' x 6'', Double 2'' x 6'', Single 2''x 10'', Double 2'' x 10'', Single 2'' x 12'', and Double 2'' x 12''. I think I have to many posts under my house , look like a jungle of posts. Anybody have a clue??
Ken Andersson is offline   Reply With Quote
Old 03-08-2010, 09:54 AM   #2
Typically posts will be every 8 ft unless engineered to be more widely spaced. You shouldn't take them out without talking with a structural engineer or experienced builder who's willing to pull a permit.
walkman is offline   Reply With Quote
Old 03-08-2010, 11:30 AM   #3
a span table will get you headed in the right direction, but like walkman said don't do anything without consulting an engineer or builder.
cellophane is offline   Reply With Quote
Old 03-08-2010, 12:30 PM   #4
Better to have more post then less, what if your son's football team decide to come over and have a dance party in your living room? any reason why you would want to pull out perfectly good posts?
Frostbite is offline   Reply With Quote
Old 03-08-2010, 02:08 PM   #5
The span will depend a great deal upon the load above
An engineer or possibly a good lumber yard could run the numbers
I think you maybe confusing the BEAM that supports the floor joists with the span of a floor joist
BEAM span is much different & takes more to calculate
Depending upon species, grade of wood & distance between joists:
2x6 will span less then 10' without an additional load
2x10 will span ~15' without an additional load
2x12 will span ~17' without an additional load
Again - this is the floor joist span
NOT The span for the beam that the floor joists sit on
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 06:50 AM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 10:45 PM
open span under hipped roof..... SickPuppy Carpentry 3 06-06-2008 11:24 AM
Max span for 4x8 header? MusicMan_234 Building & Construction 2 05-29-2008 12:17 PM
