Construction Of A Second Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 05:57 PM   #1
Construction of a second floor
I currently have a two story living room and would like add a bedroom above the living room. This would now make the living room a one store room and above it would be the new bedroom. My question is can I use a ledger board and bolt it to the exterior walls (inside the house). The ledger board would be connected basically the same way as a deck of a second story. Please offer me help and if this is allowable in New Mexico?
dslusser is offline   Reply With Quote
Old 09-01-2010, 05:58 PM   #2
so does this mean I will not get any kind of answer.
Old 09-01-2010, 06:12 PM   #3
REALLY ??
You waited a whole minute for a reply ???
Old 09-01-2010, 06:25 PM   #4
sure, you should be able to do that just fine.
more ideal would probably be to open the wall, bolt the ledger, and then run the joists over the top of it and face nail into the studs too.
but hanging them off the face of the ledger with joist hangers should be perfectly fine.
wombosi is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Jacuzzi Whirlpool bath floor construction eemc2 Building & Construction 6 02-03-2010 09:14 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
How to level basment floor and keep floor drain Bcoleman6 Flooring 2 07-20-2008 06:23 AM
