Construction Adhesive - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-18-2009, 11:04 PM   #1
Rewards Points: 91
construction adhesive
just used heavy duty construction adhesive in my caulk gun and am hoping to use it over 2-3 times over the next 3-4 days. It didn't come with any kind of cap - what's the best way to keep it healthy during this period - just cover the end with a paper towell, or do i need to use a new one each day?
thanks!
mmhendrie is offline   Reply With Quote
Old 03-18-2009, 11:32 PM   #2
Registered User
Termite's Avatar
The paper towel won't work. I'd say your best bet is to take some plastic wrap and cover the end tightly, then rubber band it on. That stuff gets pretty hard pretty quick.
Old 03-19-2009, 07:21 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
if it does harden just cut the tube back alittle
Tom Struble is offline   Reply With Quote
Old 03-19-2009, 07:49 AM   #4
thanks!
If I remember, I stick a screw/nail in it, otherwise I ususally forget and just re-poke the hole
skizsam is offline   Reply With Quote
Old 03-19-2009, 07:28 PM   #5
Tape it closed with electrical tape!
Old 03-19-2009, 07:38 PM   #6
Five Star's Avatar
dont forget to pull back or release the pressure on it or no matter what you put on the tip its all gonna OOZZZ out all over your goodies!
Five Star is offline   Reply With Quote
Old 03-19-2009, 07:53 PM   #7
Old School
Willie T's Avatar
With any caulking, when you cut the little tip off the tube....... save it, and stick it back into the hole (point first) when you're done.
Willie T
Old 03-19-2009, 08:00 PM   #8
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,336
My method is... put a nail in it, put the tube in a large zip lock, and finally put it in the fridge.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-19-2009, 08:24 PM   #9
Rewards Points: 1,088
thanks!
When I buy caulk, I normally go for the tube that has a screw off spout. A cap just doesn't work as well.
That way, after awhile, you can always unscrew the spout, and pry the dried contents out, while the adhesive/caulk inside the tube is still uncured.
handy man88 is offline   Reply With Quote
Problems with Omni Grip tile adhesive Blue Flooring 24 05-15-2016 07:37 PM
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 01:47 PM
Storing PL Premium construction adhesive Nestor_Kelebay General DIY Discussions 14 12-19-2008 07:03 AM
Use construction adhesive for box install? rgsgww Electrical 7 11-28-2008 11:02 AM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
