Old 05-08-2010, 11:10 PM   #1
construction
Hi, i have a 16x32 outbuilding and i was wondering if i can remove the ceiling joist without hurting the stucture of the building? the joist are 2x4's. thanks for any info
zman890 is offline   Reply With Quote
Old 05-08-2010, 11:19 PM   #2
Old School
Willie T's Avatar
construction
Probably not. Those 2x4's are likely keeping the two side walls of the building from being shoved apart by the rafters.
Willie T
Old 05-10-2010, 02:59 AM   #3
construction
Got any pictures? Removing ceiling joists has an ominous ring to it. Do you believe they were added just for excess (overkill) or do they look like they NEED to be there? Tough call w/ out a picture, but I'd be leery. People don't often put a bunch of wood in a ceiling just for kicks and giggles. Are the 2x4s the bottom cord of a truss? A 16' span is a long-butt way for a 2x4 to go all by itself; way, way long.
Window replacement Help (New Construction) gregt848 Building & Construction 3 10-18-2009 07:59 PM
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 02:47 PM
Which is better? (Non-vented roof construction with indoor pool) elbartee Roofing 21 03-27-2008 12:05 AM
Rafter Construction janetng Building & Construction 2 07-13-2006 07:58 AM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 04:57 PM
