Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2010, 08:13 PM   #1
Construction
I am going to take old metal siding off 2x4 Double wide. Install 2" Blue Styrofoam
SM, Plus 8 New Windows with 6" Jams. Do I need House Wrap as Well?gorddebwatson@shaw.ca
gord watson is offline   Reply With Quote
Old 01-02-2010, 07:01 AM   #2
Remodeling Contractor
it would be recommend. The house wrap works as an air barrier. Helps keep wind driven moisture out of the insulation and building. Good look attempting to reuse this siding. Not likely to be successful. I would suggest finding a source to get more of the same or cost out a total new replacement.
New construction Window Advice bill19765 Building & Construction 2 11-07-2009 09:12 AM
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 02:47 PM
Block Wall House Construction in Ensenada Mexico jeff starr Building & Construction 1 04-22-2008 09:05 PM
Which is better? (Non-vented roof construction with indoor pool) elbartee Roofing/Siding 21 03-27-2008 12:05 AM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 04:57 PM
