Old 01-24-2012, 01:00 PM   #1
construction
I'm building a frame for a small greenhouse. and I would like to know if a sixteen foot long 2x4 on edge supported at each end would be strong enough to support two layers of six mil. plastic and snow. I will have a five to six inch rise per foot.
Thanks: bill
billsfree is offline   Reply With Quote
Old 01-24-2012, 01:19 PM   #2
Framing Contractor
construction
Nope.
sixeightten is offline   Reply With Quote
Old 01-24-2012, 01:27 PM   #3
EIT/DIY'er
construction
Not enough info. ASSUMING the plastic is strong enough and your method of fastening is adequate, we'd still need to know how far apart the 2x4s are spaced and what area you're in.
That being said.....no, I do not believe it will be strong enough.
If you're looking at building this just as you would build, say, a shed but using plastic sheeting instead of roof decking and roofing material, you need to keep in mind that the decking provides lateral support and stiffness to the structure.
If this were my backyard project, I'd build this just as I would a shed or garage, with the same size framing, then use longitudinal 1x material across the rafters of the shed/gabel/whatever roof you're looking at building (as well as the sides assuming they're going to be unsheathed).
Then I'd take a good hard look at the strength of the poly and how to properly fasten it.....maybe someone with more knowledge than I have will come along to give you some info on poly.
Lattimer is offline   Reply With Quote
The Following 2 Users Say Thank You to Lattimer For This Useful Post:
billsfree (01-24-2012), mae-ling (01-24-2012)
Books that teach the basics of construction - recommend them to me? costafinkel Building & Construction 13 08-05-2011 12:32 AM
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 07:05 PM
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 02:47 PM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 04:57 PM
