Old 10-05-2005, 11:06 PM   #1
Default constructing a hidden doorway
I just took possesion of a home that came with a wonderful loft that I intend to turn into an office. Off this loft area is an unfinished room over the garage. What I would like to do is finish the ROG and where the existing doorway is, I would like to install a hidden doorway that includes a set of shelves that match the existing built-in shelf units. The simple answer would be to attach the shelf unit to the door, but I realize that the existing hinges would not hold the additional weight of the shelves, let alone any books. I also need information about a latching mechanism for the doorway. The intent is to make this a safe room should there be any type of home invasion, etc. since it is opposite the master suite. Any help, as far as resources or advice, will be greatly appreciated.
bubblehd is offline   Reply With Quote
Old 10-15-2005, 04:13 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You should be able to attach matching bookshelves to the existing door by adding strong cross-bracing to the other side, and a small roller under the outer swing end of the door. You also could add larger gate hinges on the back side. Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
More On This Topic
Hello my name is Denise Robinson on behalf of Expert Village I'm here to talk about the loft. How to take a space a large space and divide it up into small living quarters. We're in our dining area and I'm going to decorate the shelf that will set behind... Read More »
Hi I'm Denise Robinson and on behalf of Expert Village I'm here to talk about the loft. How to take a space a large space and divide it up to small living quarters. Okay now we're moving on to our next area in our loft. This is our dining area and here... Read More »
I'm Tony Ramirez from Tampa, Florida and on behalf of Expert Village this is how to build a cd rack. In my case a media rack. Let's go! So I have removed all of my existing shelving that I had up already. Of course all the media that was on it. Now what... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we would be laying out our shelves. Since we made each opening of our project the exact same size our shelves are all going to be the same in width. As I measure that opening I get 21 13/16... Read More »
How to Remove Shelf Paper
How to Remove Shelf Paper by Expert Village
Hi, this is Jon on behalf of Expert Village. In this video clip we will be removing our shelf and cleaning it. Our next update is to put new shelf paper on our closet shelves. Now, these old ones the shelf paper has started to come off, its been torn in... Read More »
Considering widening interior doorway - How difficult? davewolfs Remodeling 11 05-23-2007 03:26 PM
Widening a doorway in a load bearing wall EFEmm Building & Construction 3 03-23-2007 09:17 AM
Need to Cement Up old Basement Doorway BigArnold Building & Construction 1 12-29-2006 05:52 PM
Sealing a Standard Doorway seal8682 Building & Construction 5 09-06-2006 08:31 PM
how to-create doorway in load bearing wall Nikkil Building & Construction 1 05-17-2005 01:06 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
