-   -   constructing a hidden doorway (http://www.diychatroom.com/f19/constructing-hidden-doorway-1108/)
bubblehd 10-05-2005 09:06 PM
I just took possesion of a home that came with a wonderful loft that I intend to turn into an office. Off this loft area is an unfinished room over the garage. What I would like to do is finish the ROG and where the existing doorway is, I would like to install a hidden doorway that includes a set of shelves that match the existing built-in shelf units. The simple answer would be to attach the shelf unit to the door, but I realize that the existing hinges would not hold the additional weight of the shelves, let alone any books. I also need information about a latching mechanism for the doorway. The intent is to make this a safe room should there be any type of home invasion, etc. since it is opposite the master suite. Any help, as far as resources or advice, will be greatly appreciated.
Mike Swearingen 10-15-2005 02:13 AM
You should be able to attach matching bookshelves to the existing door by adding strong cross-bracing to the other side, and a small roller under the outer swing end of the door. You also could add larger gate hinges on the back side. Good Luck!
Mike
