Constructing A Crawl Space. Part Ledge Rock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2015, 01:06 PM   #1
Rewards Points: 2
constructing a crawl space. part ledge rock
I am about to start excavating for a crawl space, and continuing on to build the crawlspace from there. 23 x 48, and 16 x 27. Westchester County NY, northern western lower cost part of County. The house foot print is a T, everything square edges. The house is modular. The 'base' part of the T is 16 x 27 and is in an area of ledge rock. I m going to have to get 4' or so of ledge rock off to get to grade, and then keep going to go below grade. I m assuming that I can pin the crawl space wall to the ledge rock. I am assuming that I will not have to go below the frost line for this part of the crawl space, as the rock will be considered part of the foundation. For the 23 x 48 part there is not any ledge rock appearing, and I m assuming the crawl space wall will be 18" (?).
Questions:- back hoe or excavator for where there is no ledge rock? what size of bucket? what size of backhoe or excavator - 16K, 24K? for the ledge rock I will hammer it with a hammer on the 24K - good plan? Any insights / answers appreciated.
keepitmoving is offline   Reply With Quote
Old 06-16-2015, 05:28 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,588
Ayuh,....... You'll want the biggest hammer-hoe you can rent,....
Smaller hoes can dig, 'n move the rumble,...
Water in crawl space ratherbefishing Building & Construction 2 07-19-2014 09:10 AM
Crawl Space Advice Perry401 General DIY Discussions 6 02-22-2014 02:23 PM
Crawl Space Questions mark2741 Building & Construction 1 12-23-2011 11:20 PM
Crawl space moisture/water removal KAdams4458 Building & Construction 7 04-24-2011 12:21 PM
crawl space and moisture Jeremy Hillary Boob, PhD Building & Construction 5 11-27-2008 08:13 PM
