Connecting Rim Joist To Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2008, 01:56 PM   #1
Rewards Points: 154
Connecting rim joist to deck
I notice in many deck building books they use joist hangers to connect the rim joist to the ends of the main floor joists. Since the joists are already supported by the outer beam are they necessary? I am more inclined to toe in a bunch long screws from the outer surface of the rim joist. What are your thoughts.
ovahimba is offline   Reply With Quote
Old 01-18-2008, 02:51 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
No, they are not necessary on the end that is structurally supported by the beam and posts - that are UNDER them.
However, you should attach the joists to the beam with some simpson brackets or hurricane type brackets.
- Build Well -
Old 01-18-2008, 03:01 PM   #3
Mod / ArchiBuilder
Cole's Avatar
I agree, in most cases joist hangers on the rim joist are overkill.
Cole is offline   Reply With Quote
Old 01-18-2008, 07:53 PM   #4
Rewards Points: 154
Thanks for the reply. I thought so.
Old 01-19-2008, 07:36 AM   #5
Framing Contractor
They are not necessary. All you have to do on top of the girder is toenail the joist into it. Where I'm from, that's all you need, you don't need any hardware where the joist connects to the girder. Maybe you do where you're from.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-19-2008, 08:33 AM   #6
Originally Posted by Joe Carola View Post
....you don't need any hardware where the joist connects to the girder. Maybe you do where you're from.
Yeah, in my area it's pretty much by the town.
We've run into enough to where we just go ahead and install them as normal procedure.
- Build Well -
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 03:09 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
Deck vibration problem tpmanus Building & Construction 15 04-25-2007 09:37 AM
