Old 11-04-2009, 02:18 PM   #1
Default Connecting Ledger Board to Vertical Stud
This may be hard to explain, but here goes. I want to install a ledger board on a flat interior house wall (in a 2-story room), from which I plan to hang 2x10 joists (that will run 12' over to another wall). Installing the ledger would be no problem, except that there's a tall window at the end of my run. And, I want the ledger board to end in the middle of where the window is currently located. I will, at some point, be removing this window and replacing it with vertical studs, but I want to put this off until later, mainly because I plan to do the interior work during the winter. So, what I'm thinking is that I will let the ledger board extend beyond the window (i.e. span it), and then cut the protruding section (maybe 18") of the ledger board off later after I have installed studs where the window is now. OK...so my question is, how would I attach the ledger board to the vertical studs at the point in time where I have access only to the outside (the side facing the studs) of the ledger board? I understand that I could nail or screw from the outside into the ledger board, but then I'm relying on the shaft of the nail or screw to hold up the weight of the floor. I also though of installing something (a bracket?, a bolt?) on the ledger board while I have access to the other side, which will attach to the studs when they're in place. Any ideas, suggestions? Thanks!
Alzipski is offline   Reply With Quote
Old 11-04-2009, 02:35 PM   #2
Sounds as if you are putting a floor in a clear story room, 1/2 way up. If so I suggest you refer to a structural engineer for help. He/she would be responsible for: the length, diameter and spacing of the lag bolts (not just two on every stud) for the ledger, the strength of the interior wall and joists below holding up the additional floor weight, and the general responsibility of the floor system. It will be much easier to get your permit to ensure the safety of anyone using the new floor space.
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 11-04-2009, 04:15 PM   #3
Thanks, I'm sure that hiring an engineer would be the answer to my problem, but I'm hoping there are carpenters reading this who have their own ideas on how this would be done.
Old 11-04-2009, 04:53 PM   #4
Here's my idea, but I wouldn't do it in my house without an engineer's seal:
Tear the wall down to the studs. Sister 2x6s to the 2x4s and put the ledger on top of the 2x6s. Then rest the joists on top of the ledger and lag them to the 2x4s.
It's basically what we came up with for putting a tray ceiling into an existing house, but in the end we went with a normal ceiling.
pyper is offline   Reply With Quote
More On This Topic
Hi this is Jon on behalf of Expert Village, in this video clip I will show you how to prepare our wall studs. On our Styrofoam installation our wall studs fall behind this diamond line. In addition the studs falls where the Styrofoam pieces fit together... Read More »
Your sunroom is could be sitting empty most of the time, because it's too hot in the summer and too cold in the winter. Your sunroom can become a place for year-round enjoyment with a few easy steps. Imagine it as a haven--a place to sit and read, eat or... Read More »
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
Hi! I'm Amelia on behalf of expertvillage.com. I am here today talking about how to change over windows from curtains to interior set wooden blinds. So it is recommended for blinds that are of width greater than 27 inches that you install the center... Read More »
Hi! I'm Amelia on behalf of expertvillage.com. I am here today talking about how to change over windows from curtains to interior set wooden blinds. So this is the type of blind that we chose. These are actually Felwood blinds. You can get these both to... Read More »
Ledger Board Help cbeingessner Building & Construction 0 05-17-2009 08:01 PM
Ledger Board Mounting Wildie Building & Construction 6 04-05-2009 12:02 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 09:38 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 11:16 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-07-2006 12:50 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
