Confused With Code Requirements About Structural Sheathing. - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-15-2008, 09:12 PM   #16
That would be the easiest if he passes it off.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-19-2008, 08:36 PM   #17
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
Follow Up:
I spoke with the building inspector today. Told him what I was doing and that I only had 21" of shear wall on each end. He didn't have a problem with it. I guess I should put the book down and not try to decipher it.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-19-2008, 09:57 PM   #18
Builder/Remodeler
mpepin's Avatar
Clutchcargo, you were on the right track. iLevel, Simpson and Hardy Frame all sell products to do that. There's also an APA detail for narrow walls. Google "APA narrow wall" or "APA portal frame" and you'll find framing details. Of course, if your inspector doesn't care, you don't have much to worry about!
mpepin is offline   Reply With Quote
Old 11-20-2008, 09:57 AM   #19
I have gas!
Even though he said he would pass it, I'm ging to still put a K-brace on each end to make it a little stiffer.
The original was T&G plank sheathing with windows about 8" from the corners and it didn't rack in 85 years without a hint of shear wall so I'm probably making more out of this than it's worth.
Old 11-20-2008, 10:17 AM   #20
I think that is a smart move. Hey, it's only a few pieces of lumber but a lot of piece of mind.
code details for boxes kama Electrical 6 01-30-2009 11:25 AM
structural sheathing. Clutchcargo Building & Construction 13 09-24-2008 07:25 PM
What was the code requirements on amperage? rgsgww Electrical 3 09-05-2008 12:33 PM
Code requirements for Vent fan? Indianer Building & Construction 11 06-12-2008 09:30 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 11:06 AM
