Confused About Vapor Retarder Requirements - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 06:22 PM   #1
Confused about vapor retarder requirements
I am in zone 3, and I was able to find the R value requirements pretty easily. However the vapor retarder part is a bit confusing. Some documents say you need it on the interior, some say exterior, some say none at all and that paper kraft or paint has the right permeability. I've even read somewhere that you can sandwich vapor barrier between 2 layers of insulation.
I am so confused. Is there a definitive answer for this?
acerunner is offline   Reply With Quote
Old 07-30-2010, 01:05 AM   #2
Registered User
Rewards Points: 4,936
So.... what did your local building department say?
http://www.buildingscience.com/docum...ecommendations
Be safe, Gary
Difference between 220 and 240 volt requirements? cleveland Electrical 7 04-14-2010 08:24 AM
Code requirements for low voltage wiring in conduit with 120V flyboy Electrical 9 12-24-2009 07:48 PM
Confused about Sub Panel stqevo Electrical 28 10-02-2009 12:04 AM
Trying to wire my bathroom... confused... Alan Electrical 3 11-23-2008 05:44 PM
Confused with code requirements about structural sheathing. Clutchcargo Building & Construction 19 11-20-2008 10:17 AM
