Old 07-21-2012, 11:50 PM   #1
confused about permits
Hi All, we are purchasing a home that needs some "minor" updates and we are trying to save money. I want to make sure we get the permits we need though. I called the town code enforcement, but I think the guy was a little biased because I'm a woman and told me I should just hire a GC and not worry about it and then hung up on me. Anyways, I began reading the code handbook.
We need some electrical - need a permit.
painting, flooring, counters, cabinets - no permit needed.
bathroom tiling - no permit needed
what if I want to expand the entryway into a room (i.e. from the kitchen to the dining room?). I'm not knocking down the whole wall (although a big chunk of it) - do I need a permit for this? if it's not a structural change do I need to submit plans?
dry-wall?
I plan on calling the code enforcement again and if it comes down to it I will go visit them, but any insight would be appreciated as I'm sort of weary of them as they weren't too friendly to begin with. TYIA.
laorquidia is offline   Reply With Quote
Old 07-22-2012, 02:00 AM   #2
Electrical - You need a permit, and some areas only allow licensed electricians to do the work.
Counter tops - My local building department actually requires if a counter top has a sink in it.
Expanding an entry way - Probably needs a permit, may need an engineer to sign off depending on the amount of the change, if it's a load bearing wall, etc.
Drywall - Maybe. I could see them wanting a permit if you're touching a firewall.
I'd suggest checking to see if your local building department has a webpage that states what work doesn't require a permit. For more information, I'd suggest actually visiting the building department. I've found the folks at my local building department much nicer and more helpful if I visit them in person.
a_lost_shadow is offline   Reply With Quote
Old 07-22-2012, 02:15 AM   #3
GBrackins's Avatar
if you go to this link it is from the Massachusetts Board of Building Regulations and Standards. It is for frequently asked question. Click on the link for "Work Requiring HIC or CSL" and it gives you a list of items and whether a permit is required or not. Hope this helps!
http://www.mass.gov/eopss/consumer-p...mits-faqs.html
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
laorquidia (07-22-2012)
Old 07-22-2012, 08:09 AM   #4
Thanks all! The link was very useful!!
Old 07-22-2012, 08:26 AM   #5
the Musigician
DangerMouse's Avatar
I thought you needed a permit just to BREATHE in MA.?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
Fix'n it (07-22-2012)
Old 07-22-2012, 09:01 AM   #6
Moderator
kwikfishron's Avatar
Skip the call and just go down there.
I've found that face to face with the building department is almost always more productive than a phone call.
It's much easier to brush you off when they can't see you, as you already found out.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
GBrackins (07-22-2012)
Old 07-22-2012, 06:39 PM   #7
GBrackins's Avatar
DM
depends where you are .... being on the bay we don't have much issue getting air .... it's a lot tougher now than a few years ago with the regulations, but you learn to adapt, improvise and overcome
Gary
Old 07-22-2012, 08:30 PM   #8
Require the installing contractor to pull the permits. Whoever applied for the permit(s) is responsible for all corrections if the work fails inspection.
You may find that as a homeowner you are not allowed to self-perform any work for which a permit is required.
MI-Roger is offline   Reply With Quote
Estimate for plans + permits + sub-foundation stuff + foundation? shinyhalo Building & Construction 5 10-07-2011 09:29 PM
Help ... permits joyjoy Remodeling 2 11-26-2010 07:30 AM
Confused about Sub Panel stqevo Electrical 28 10-02-2009 12:04 AM
New, Confused Homeowner LoneRanger Building & Construction 1 09-11-2009 07:30 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
