Confused About Perimeter Drains... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-10-2013, 11:50 AM   #1
Rewards Points: 948
confused about perimeter drains...
I bought a house 10 months ago. The street is about 40' away in the front, and a lake is about 50' away in the back. The walkout basement is about 15' above the lake, and the street is about 3' above the top of the basement. There is a drainage ditch on the other side of the street; my side is flat.
When we bought the house the sump was full of extremely stagnant water, which I pumped out.
Yesterday we had an extremely long heavy rain that left puddles in the front and back yard. I checked the sump and it was empty, and the walls were dry. The sump being empty confuses me.
I checked the plans and there are lines of 4" PVC storm that I think goes to the rain gutters. Just outside the foundation and just inside the foundation are lines of 4" PVC perf; presumably these are the perimeter lines. I further presume that everything drains to the lake; there are plenty of pipes sticking out the breakwall.
Now for my question?
What is the purpose of the sump? It has two pipes at the top, so if it fills it never empties. It is not shown on the plans.
Thanks, and sorry for being so long winded; just wanted to provide all possible information.
Toller is offline   Reply With Quote
Old 07-10-2013, 08:32 PM   #2
Concrete & Masonry
Rewards Points: 548
The simplest answer is that sump crocks are required at time of construction in some areas. That's the case here, sump crocks are required, but pumps are optional. In many walk-out basements, the crock will likely never see water, as the draintile outside are much lower than the crock itself.........
jomama45 is offline   Reply With Quote
Old 07-11-2013, 06:41 PM   #3
Rewards Points: 948
Sadly, that makes sense. Thanks.
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
A breach in the footings = water? Daler Plumbing 15 09-08-2010 08:40 PM
Bathroom perimeter joints: just leave 1/4" open on perimeter if wood trim will hide? lazzlazz Tiling, ceramics, marble 0 04-23-2010 03:01 PM
Basement Drains?? edbusjr Plumbing 1 12-29-2009 07:11 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
