Confused About Insulating Kneewall Attic Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-27-2013, 12:19 PM   #1
Rewards Points: 59
Confused about insulating kneewall attic space
I am confused with all the different options concerned with insulating a knee wall attic space in my Cape Cod home. Presently, there is insulation on kneewalls (fiberglass r-13). There is no insulation on roof deck boards or baffles. There are soffit vents and a ridge vent. The room is extremely hot in summer and cold in winter. What are the best options aside from spray foam to make this area of my home more comfortable and energy efficient? What about the following: Blocking under knee wall to stop air infiltration under floor and downstairs ceiling? 2. Is it allowed for some type of board (plywood, foam board, OSB) on the backside of the knee wall to stop air infiltration into living area? Is there a concern with moisture and mold? 3. If I put baffles on roof deck then insulation over baffles would that maintain more tolerable temps in this area? Is there concern with damage to roof deck with regards to moisture or heat in summer? 4. What to do for attic ceiling? Thank you Tim
EFTHIM is offline   Reply With Quote
Old 12-27-2013, 04:01 PM   #2
Tim,
Is the floor floored to outside walls? If not, seems like you could at least insulate the ends of the cavities between ceiling and F. joists.
Code says; you must maintain a 1" air space between insulation and bottom of roof sheathing. So baffles here are good.
Rooms like this are known to be hard to condition. So much outside exposure and difficult to run ductwork.
glkirk is offline   Reply With Quote
Insulating converted stand-up attic to living space mudpaws Insulation 3 09-19-2013 04:28 PM
Attic Ventillation Problem. Why Now? Hubs Roofing/Siding 2 03-19-2013 10:23 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Insulating the attic in my Cape cod daddymikey1975 Insulation 14 01-24-2012 07:21 AM
Looking to utilize attic space - questions dwoloz Building & Construction 5 08-05-2010 07:35 PM
