Condo Balcony - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 09:15 AM   #1
condo balcony
i need to fix up my ceiling on the balcony, it has a big chunk that fall off the edge of it . the building is quite old, what can i do and use
antoni is offline   Reply With Quote
Old 06-01-2011, 09:18 AM   #2
Rewards Points: 1,578
What is the ceiling material made from? A picture might help. How big is the area that fell? Why did it fail and fall as you might want to prevent it from happening again?
bob22 is offline   Reply With Quote
Old 06-01-2011, 06:14 PM   #3
Rewards Points: 4,578
in most states, exterior work is the province of the condo assoc,,, we do a fair amount of condo work but NEVER for the individual unit owner - ONLY for the condo assoc.
repair method's fairly simple - 1, delineate the size of the damaged conc which will often be much larger than your broken piece; 2, sawcut the outline of the patch; 3,chip off the bad conc to find good; 4, scarify the existing conc to provide a good mechanical 'tooth' for your selected repair mortar; 5, select the right repair mtl & apply if properly; 6, cure per directions.
ps - be sure you've got rebar in the right space,,, tie it to the existing bar OR install it per icri specs,,, we like epoxy coated bar for balcony work.
pps - be sure your insurance will protect you in case any falling debris injures anyone OR damages any property.
pps - this will likely be permitted work meaning stamped engineering/architectural drawings.
ppps - you may also be required to be compliant w/ALL osha specs AND post a performance bond.
you absolutely sure you want to do this on your own ? it may be your ceiling BUT the responsibility for the repair is on the upstairs owner according to most laws,,, its HIS deck, not yours
Old 06-02-2011, 08:07 AM   #4
here's a place to begin - http://www.durabilityanddesign.com/n..._versionid=966
Installing a ABS Pipe on a Balcony Donnythecat Building & Construction 13 03-18-2011 07:01 PM
Problem with Condo (boiler pipes) Video Included. BA! HVAC 2 01-15-2009 06:14 AM
High Rise Condo Thermostat Change omanalansan HVAC 8 10-24-2008 02:57 PM
balcony delema onthelevel Carpentry 2 09-13-2008 10:53 AM
Condo Balcony above leaks on my patio mightyj2u Building & Construction 2 08-22-2008 08:32 PM
