Condensation From The Steam Heat Causing Icicles On Exterior Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 07:11 PM   #1
Condensation from the steam heat causing icicles on exterior walls
I have icicles on exterior walls. It has not rained or snowed in last several days. Can steam heat pipe leak in the wall and cause condensation?
JG198 is offline   Reply With Quote
Old 12-18-2010, 01:38 AM   #2
Rewards Points: 1,092
Sure, but you also may have wall problems. Often, moisture in walls is due to having the interior humidity way too high (about 30-40-ish% RH is recommended) and/or poor air sealing. Air leakage carries water with it, then hits something cold and freezes. Do you have fiberglass insulation? Old house, or new?
Old 12-18-2010, 07:24 AM   #3
It is old house. I do not know about type of insulation.
Old 12-18-2010, 08:09 AM   #4
Rewards Points: 5,336
Once the steam leaves the pipe it condenses. You should be able to trace the steam pipes in this area to determine if they are the cause. You should also look into the water supply and the drain systems in the house.
If you can't find it this morning, call someone or the damage to the house can be substantial.
Ron
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
One Pipe Steam Heat ? II Weeks HVAC 8 03-06-2010 07:54 AM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 01:17 PM
Bypass duct causing smelly heat? moto327 HVAC 2 11-30-2009 06:36 PM
Steam causing microwave door to "peel"? K1NJO General DIY Discussions 5 05-15-2007 10:59 AM
