Condensation Stains From Weathered 2x4 Trusses In Solarium Attic Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-10-2010, 03:38 PM   #1
condensation stains from weathered 2x4 trusses in solarium attic space
we have a 50 x18 solarium wood truss space that was constructed by dad before his passing. The sun has weathered these trusses black/brown and when cold weather arrives the trusses condensate and run colored water down onto the corlon panels we have installed between the bottom course of the trusses thereby discoloring them profusely in a totally unsightly mess in our winter solarium constructed between our u shaped house.Any suggestions greatly appreciated.
chris boland is offline   Reply With Quote
Old 06-10-2010, 04:16 PM   #2
DIY staff
Rewards Points: 7,174
A picture or two will help---Obviously insulation is needed--but the how and where --will require more info.
Mike
Old 06-10-2010, 09:36 PM   #3
Registered User
Rewards Points: 5,206
Little late now to seal the wood by painting or staining..... normally applied before the glazing panels are installed or tinted.
Be safe, Gary
Gary in WA is online now   Reply With Quote
Old 06-11-2010, 01:13 PM   #4
Rewards Points: 3,130
You can try a mild bleach solution in a pressure washer - this is common for log homes. There's also corn cob blasting, but that is $$$$.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Remodeling Attic Space jte1130 Remodeling 2 04-04-2008 06:06 PM
Birds' nest in attic crawl space Frances Pest Control 1 09-01-2007 05:48 PM
condensation from ac in crawl space Jack Hass HVAC 6 08-23-2007 07:01 PM
rats is my crawl space and in my attic this old house Pest Control 5 06-02-2007 06:48 PM
